2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: double filters
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Fri, 3 Apr 2020 19:42:51 +0200
Hi Andrew,
Am 30.03.20 um 06:08 schrieb Johnson, Andrew N.:
> I’m also thinking of a put filter where you can give individual array
> index values to be written to, so to create a filter that only
> overwrites specific elements of the target array you might want to
> specify a channel filter as
> pvname.{“subset”:[0,1,2,4,6,10,12,16,18]}
> The idea is that there might not be an arithmetic slice/stride
> pattern to the index values.
I have implemented this proposal, albeit with plain bracket notation,
that is you specify "PV[0,1,2,4,6,10,12,16,18]" directly. It is just
another form of address modifier, alongside the "PV[s:i:e]" notation.
The code is probably buggy since I haven't done serious testing yet,
just some experiments with caput and a simple soft IOC. If you are
interested, this is the latest commit on my work branch:
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+ref/work
I have also updated all my merge proposals with a forced push to get rid
of unwanted commits and to avoid conflicts with 7.0.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
Re: double filters Ben Franksen via Core-talk
Re: double filters Johnson, Andrew N. via Core-talk
Prev: Build completed: EPICS Base base-3.15-577 AppVeyor via Core-talk
Next: Re: double filters Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: double filters Ben Franksen via Core-talk
ANJ, 03 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
