2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: AppVeyor issue
From: "Konrad, Martin via Core-talk" <core-talk at aps.anl.gov>
To: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Mon, 13 Apr 2020 20:49:33 +0000
Hi Freddie,
> you could specify this image explicitly for the 10.0 11.0 12.0 and
> 14.0 toolchains (as is done for mingw in the file)
Thanks, that works :-) After deleting the project and starting from
scratch I believe that's actually the only thing that fixes my problem
(setting the default in the settings did NOT work for me - AppVeyor is
ignoring that the same way it is ignoring what should be their own
default...).
Thanks for your help!
-Martin
P.S.: I opened a MR:
https://code.launchpad.net/~info-martin-konrad/epics-base/+git/epics-base/+merge/382142
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: konrad at frib.msu.edu
Re: AppVeyor issue Ralph Lange via Core-talk
AppVeyor issue Konrad, Martin via Core-talk
Re: AppVeyor issue Konrad, Martin via Core-talk
Re: AppVeyor issue Michael Davidsaver via Core-talk
Prev: [Merge] ~info-martin-konrad/epics-base:explicitly-specify-appveyor-worker-image into epics-base:3.15 Martin Konrad via Core-talk
Next: Re: Graceful Shutdown with joinable thread Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: RE: AppVeyor issue Freddie Akeroyd - UKRI STFC via Core-talk
Next: Re: AppVeyor issue Ralph Lange via Core-talk
ANJ, 14 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
