2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Graceful Shutdown with joinable thread
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Kukhee Kim <khkim at slac.stanford.edu>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Mon, 13 Apr 2020 21:48:11 +0000
Hi Kukhee,
On Apr 1, 2020, at 10:59 AM, Kim, Kukhee via Core-talk <core-talk at aps.anl.gov> wrote:
I am wondering about our evolutional direction:
Are we going to keep the un-joinable thread as a default? Or, migrate to the joinable thread?
We will not be changing the default settings for any existing epicsThread API, as doing so would potentially break external code. That doesn’t mean that any new APIs we introduce will have the same defaults though, just that existing code shouldn’t have to be changed to continue working with future releases (unless we decided to remove the old APIs completely, which is unlikely in this case).
- Andrew
Complexity comes for free, simplicity you have to work for.
Graceful Shutdown with joinable thread Kim, Kukhee via Core-talk
Prev: Re: AppVeyor issue Konrad, Martin via Core-talk
Next: Jenkins build is still unstable: epics-base-3.15-win32-test #286 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Graceful Shutdown with joinable thread Kim, Kukhee via Core-talk
Next: Build failed: EPICS Base base-7.0-572 AppVeyor via Core-talk
ANJ, 13 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
