2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+382303 at code.launchpad.net
Date: Fri, 17 Apr 2020 07:42:29 -0000
I will push a new version which produces empty 'git diff --ignore-all-space' output and which is re-based to the laterst 7.0. I can continue resasing it until Andrew is done with the pending merges. I am also willing to do the same for the 3.15 branch, so that future merges can go smoothly.
My most important issue is with the indention mixing tabs and spaces. Clearing out space at the end of lines is secondary. Least important are empty lines at eof (even though they should not lead to git blame confusion).
I will leave .dbd and .dbd.pod untouched for the moment, even though they have the same indention issue. But here I would probably aim for a consistent use of tab.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/382303
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Build failed: epics-base base-fix-epicsFindSymbol-466 AppVeyor via Core-talk
Next: [Bug 1873406] [NEW] EpicsHostArch script does not detect recent MSYS2/MinGW setups on Windows Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 mdavidsaver via Core-talk
Next: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 17 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
