2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+382303 at code.launchpad.net,Andrew Johnson <anj at anl.gov>
Date: Fri, 17 Apr 2020 11:51:14 -0000
The proposal to merge ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 has been updated.
Description changed to:
This is purely cosmetic:
1. There was a mess with tab character usage. Indention with spaces and tabs was mixed inconsistently sometimes with obviously different assumptions on tab width, even in the same file. This results in irregular, hard to read indents. Please stop using tabs in source code.
2. Clean up of space at end of line.
Can we please have a coding style guide?
For more details, see:
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/382303
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: AW: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Zimoch Dirk (PSI) via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 17 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
