2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+382303 at code.launchpad.net
Date: Fri, 17 Apr 2020 11:55:46 -0000
I took out the deletion of empty lines at eof and rebased the remaining changes onto the current 7.0 commit 85d198. I did not clean up the files in boost as they are an external, unlikely to ever change package.
'git diff --ignore-all-space 7.0' gives no output.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/382303
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Problem compiling EPICS 7 commit 85d1982 when INSTALL_LOCATION is set Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 28 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
