2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1853148] Re: mingw compiler problem with printf/scanf formats
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 29 May 2020 02:54:01 -0000
** Changed in: epics-base/7.0
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1853148
Title:
Status in EPICS Base:
  Fix Released
Status in EPICS Base 7.0 series:
  Fix Released
Bug description:
  ../db/dbJLink.c: In function ‘dbjl_integer’:
  ../db/dbJLink.c:136:16: warning: unknown conversion type character ‘l’ in format [-Wformat=]
           printf("dbjl_integer(%s@%p, %lld)\n",
  ../db/dbJLink.c:136:16: warning: too many arguments for format [-Wformat-extra-args]
  It seems that mingw does not like "%lld".
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1853148/+subscriptions
Prev: [Bug 1852653] Re: USE_TYPED_DSET incompatible with C++ Andrew Johnson via Core-talk
Next: [Bug 1829919] Re: IOC segfaults when calling dbLoadRecords after iocInit Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1853148] Re: mingw compiler problem with printf/scanf formats Andrew Johnson via Core-talk
Next: [Bug 1714455] Re: change request: filters should allow 'relaxed JSON' Andrew Johnson via Core-talk
ANJ, 28 May 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
