2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1852653] Re: USE_TYPED_DSET incompatible with C++
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 29 May 2020 02:53:50 -0000
** Changed in: epics-base
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1852653
Title:
Status in EPICS Base:
  Fix Released
Bug description:
  /usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I/C2/ioc-modules/build/BASE/7.0.2-C2-3+PH-001/include/compiler/gcc -I/C2/ioc-modules/build/BASE/7.0.2-C2-3+PH-001/include/os/Linux -I/C2/ioc-modules/build/BASE/7.0.2-C2-3+PH-001/include        -c eipIoc_registerRecordDeviceDriver.cpp
  In file included from /C2/ioc-modules/build/BASE/7.0.2-C2-3+PH-001/include/registryCommon.h:14:0,
                   from eipIoc_registerRecordDeviceDriver.cpp:12:
  /C2/ioc-modules/build/BASE/7.0.2-C2-3+PH-001/include/devSup.h:153:20: error: conflicting declaration ‘typedef typed_dset dset’
   typedef typed_dset dset;
  In file included from /C2/ioc-modules/build/BASE/7.0.2-C2-3+PH-001/include/dbStaticLib.h:22:0,
                   from /C2/ioc-modules/build/BASE/7.0.2-C2-3+PH-001/include/registryCommon.h:13,
  /C2/ioc-modules/build/BASE/7.0.2-C2-3+PH-001/include/dbBase.h:43:9: error: ‘struct dset’ has a previous declaration as ‘struct dset’
    struct dset *pdset;
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1852653/+subscriptions
Prev: [Bug 1868680] Re: Access Security file reload (asInit) fails Andrew Johnson via Core-talk
Next: [Bug 1853148] Re: mingw compiler problem with printf/scanf formats Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Build failed: EPICS Base 7 base-7.0-18 AppVeyor via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-20 AppVeyor via Core-talk
ANJ, 29 May 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
