2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Possible bug in convertRelease.pl
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Florian Feldbauer <florian at ep1.ruhr-uni-bochum.de>
Cc: EPICS core-talk <core-talk at aps.anl.gov>, Peter Zumbruch <P.Zumbruch at gsi.de>
Date: Wed, 19 Aug 2020 11:39:33 +0000
Hi Florian,
On Aug 19, 2020, at 3:10 AM, Florian Feldbauer <florian at ep1.ruhr-uni-bochum.de> wrote:
I tried your suggestion, but it does not work:
perl -CSD /opt/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
This application's RELEASE file(s) define
    IPAC =
after but not adjacent to
    SNCSEQ =
both of which resolve to /opt/epics/modules/iocStats/configure/O.linux-x86_64
Module definitions that share paths must be grouped together.
Either remove a definition, or move it to a line immediately
above or below the other(s).
Any non-module definitions belong in configure/CONFIG_SITE.
Having multiple Variables point to the same value (nothing) seems not allowed by convertRelease.pl.
We fixed that in November last year so it should work for 7.0.4 and later, but not for your version. Sorry I forgot about that issue…
- Andrew
On 8/18/20 7:31 PM, Johnson, Andrew N. wrote:
Hi Florian,
On Aug 18, 2020, at 3:32 AM, Florian Feldbauer via Core-talk <core-talk at aps.anl.gov> wrote:
I'm using Base 7.0.3.1 and have noticed a small Problem.
I tried building calc, asyn, stream and iocStats modules (in this order) using a `$(TOP)/../RELEASE.local` file, so I do not have to make site specific modifications to any of the git repos.
My RELEASE.local looks like this:
## Module directory
SUPPORT      = /opt/epics/modules
## unused "optional" dependencies
undefine IPAC
undefine SNCSEQ
undefine SSCAN
undefine PCRE
## Modules
ASYN      = $(SUPPORT)/asyn
CALC      = $(SUPPORT)/calc
IOCSTATS  = $(SUPPORT)/iocStats
STREAM    = $(SUPPORT)/stream
## EPICS BASE
EPICS_BASE   = /opt/epics/base
Now building calc, asyn, and stream works just fine, but building iocStats failed with
Definition of SNCSEQ conflicts with ASYN support.
In this application or module, a RELEASE file
conflicts with ASYN at /opt/epics/modules/asyn
  Here: SNCSEQ = /opt/epics/modules/seq-2-0-12
  ASYN: SNCSEQ = /opt/epics/modules/seq-2-2-5
Looking at ${BASE}/lib/perl/EPICS/Release.pm, the script looks only for definitions like "<macro> = <path>", but is ignoring "undefine" statements which leads to above error.
The version of GNUmake we were using when I wrote the original EPICS::Release Perl module didn’t have an undefine statement at all, it got added fairly recently. Just setting a variable to nothing is usually sufficient to resolve the above issue, so instead of your block of undefine statements above you should be able to do this:
IPAC=
SNCSEQ=
SSCAN=
PCRE=
We don’t normally use the GNUmake ‘flavor’ or ‘origin’ functions which can tell the difference, and the above approach will work with any EPICS release.
Attached is a small patch to also handle those undefine statements.
I don’t see any problem with adding support for that syntax. I see that this was discussed on tech-talk in June last year, but as you discovered that only works with one of the two RELEASE file parsers that the EPICS build system relies on. I am using a different implementation than your patch and optimizing the other code in that routine slightly at the same time, so this should appear in 7.0.4.2 or 7.0.5, whichever comes next.
- Andrew
Complexity comes for free, simplicity you have to work for.
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Possible bug in convertRelease.pl Florian Feldbauer via Core-talk
Re: Possible bug in convertRelease.pl Johnson, Andrew N. via Core-talk
Re: Possible bug in convertRelease.pl Florian Feldbauer via Core-talk
Prev: Re: Possible bug in convertRelease.pl Florian Feldbauer via Core-talk
Next: [Bug 1892190] [NEW] Building epics-base fails on musl based systems Sébastien Wertz via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: getVersionHelper.pl ignore -V option Jeong Han Lee via Core-talk
ANJ, 19 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
