2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1892190] [NEW] Building epics-base fails on musl based systems
From: Sébastien Wertz via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 19 Aug 2020 11:54:20 -0000
Public bug reported:
I am trying to build EPICS base 7.0.4 inside a docker container based on
alpine linux, which uses musl in place of glibc.
The build options used are CXXFLAGS="-DIPPORT_USERRESERVED=5000 -fPIC".
The build fails because the "backtrace" function does not exist in musl:
/usr/bin/g++ -o iocLogServer  -L/EPICS/base/lib/linux-x86_64 -Wl,-rpath,/EPICS/base/lib/linux-x86_64           -rdynamic -m64         iocLogServer.o    -lCom
/usr/lib/gcc/x86_64-alpine-linux-musl/9.2.0/../../../../x86_64-alpine-linux-musl/bin/ld: /EPICS/base/lib/linux-x86_64/libCom.so: undefined reference to `backtrace'
collect2: error: ld returned 1 exit status
Looking into epics-
base/modules/libcom/src/osi/os/posix/osdExecinfoBackTrace.cpp, which is
the only file using that function, I was in the end able to successfully
build EPICS by adding "-D__UCLIBC_MAJOR__=0" to the build options.
However, it would be better to detect the presence of backtrace() by
testing the existence of __GLIBC__ or __GNU_LIBRARY__, or,
alternatively, to provide the user with the possibility of disabling
backtrace support.
** Affects: epics-base
     Importance: Undecided
         Status: New
** Summary changed:
- Building epics-case fails on musl based systems
+ Building epics-base fails on musl based systems
** Description changed:
- /usr/bin/g++ -o iocLogServer  -L/EPICS/base/lib/linux-x86_64 -Wl,-rpath,/EPICS/base/lib/linux-x86_64           -rdynamic -m64         iocLogServer.o    -lCom
+ /usr/bin/g++ -o iocLogServer  -L/EPICS/base/lib/linux-x86_64 -Wl,-rpath,/EPICS/base/lib/linux-x86_64           -rdynamic -m64         iocLogServer.o    -lCom
  Looking into epics-
- testing the existence of __GLIBC__, or, alternatively, to provide the
- user with the possibility of disabling backtrace support.
+ testing the existence of __GLIBC__ or __GNU_LIBRARY__, or,
+ alternatively, to provide the user with the possibility of disabling
+ backtrace support.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1892190
Title:
Status in EPICS Base:
  New
Bug description:
  on alpine linux, which uses musl in place of glibc.
  -fPIC".
  musl:
  Looking into epics-
  is the only file using that function, I was in the end able to
  successfully build EPICS by adding "-D__UCLIBC_MAJOR__=0" to the build
  options.
  backtrace support.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1892190/+subscriptions
[Bug 1892190] Re: Building epics-base fails on musl based systems mdavidsaver via Core-talk
[Bug 1892190] Re: Building epics-base fails on musl based systems J. Lewis Muir via Core-talk
[Bug 1892190] Re: Building epics-base fails on musl based systems Andrew Johnson via Core-talk
[Bug 1892190] Re: Building epics-base fails on musl based systems Sébastien Wertz via Core-talk
Prev: Re: Possible bug in convertRelease.pl Johnson, Andrew N. via Core-talk
Next: epics-pva2pva-linux32 - Build # 191 - Unstable! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: getVersionHelper.pl ignore -V option Johnson, Andrew N. via Core-talk
Next: [Bug 1892190] Re: Building epics-base fails on musl based systems mdavidsaver via Core-talk
ANJ, 20 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
