2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: RE: Minor issue with base 7.0.4.1
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: "'Johnson, Andrew N.'" <anj at anl.gov>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Thu, 27 Aug 2020 22:38:55 +0000
I just did a fresh clone and I cannot reproduce the problem.  But it was definitely happening in my main working directory.  I don’t know if that is because I have a bunch of other architectures built there as well, or why it won’t fail on this fresh clone.
Sent: Thursday, August 27, 2020 4:58 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Subject: Re: Minor issue with base 7.0.4.1
Hi Mark,
On Aug 26, 2020, at 5:42 PM, Mark Rivers via Core-talk <core-talk at aps.anl.gov> wrote:
I just updated base to 7.0.4.1
When I run “make –sj clean uninstall” on Centos 7 I get the following error message:
corvette:local/epics-devel/base-7.0.4>make -sj clean uninstall
Can't open perl script "/usr/local/epics-devel/base-7.0.4/bin/linux-x86_64/fullPathName.pl": No such file or directory
I think the command worked OK, but the error message is disconcerting.
Do the changes below fix that particular problem? It will probably behave differently on my machines, so I think you will have to test it to be sure:
diff --git a/configure/RULES_TOP b/configure/RULES_TOP
index b956839ec..9cac51c68 100644
--- a/configure/RULES_TOP
+++ b/configure/RULES_TOP
@@ -33,7 +33,7 @@ UNINSTALL_DIRS += $(INSTALL_INCLUDE) $(INSTALL_TEMPLATES) $(DIRECTORY_TARGETS)
 ifneq ($(INSTALL_LOCATION),$(TOP))
   UNINSTALL_DIRS += $(INSTALL_CONFIG)
 endif
-uninstallDirs:
+uninstallDirs: | clean
        $(RMDIR) $(UNINSTALL_DIRS)
   # Remove the bin and lib directories if they have no sub-directories
@@ -41,12 +41,12 @@ uninstallDirs:
 EMPTY_INSTALL_DIRS = \
     $(if $(wildcard $(INSTALL_LOCATION_BIN)/*),,$(INSTALL_LOCATION_BIN)) \
     $(if $(wildcard $(INSTALL_LOCATION_LIB)/*),,$(INSTALL_LOCATION_LIB))
-uninstall: archuninstall uninstallDirs
+uninstall: archuninstall uninstallDirs | clean
        $(RMDIR) $(EMPTY_INSTALL_DIRS)
 archuninstall: $(addprefix uninstall$(DIVIDER),$(BUILD_ARCHS))
-uninstall$(DIVIDER)%:
+uninstall$(DIVIDER)%: | clean
        $(RMDIR) $(addsuffix /$(subst uninstall$(DIVIDER),,$@), \
            $(INSTALL_LOCATION_BIN) $(INSTALL_LOCATION_LIB))
Those are order-only-prerequisites that tell GNUmake to wait for the ‘make clean’ to finish (if you’ve asked it to do that) before deleting the top-level dir’s. However o-o-p’s don’t always do what you might expect with phony targets.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Minor issue with base 7.0.4.1 Johnson, Andrew N. via Core-talk
Minor issue with base 7.0.4.1 Mark Rivers via Core-talk
Prev: Re: Minor issue with base 7.0.4.1 Johnson, Andrew N. via Core-talk
Next: Re: Minor issue with base 7.0.4.1 Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 27 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
