2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1908305] [NEW] Default DTYP can be changed by DBD file order
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 15 Dec 2020 20:54:11 -0000
Public bug reported:
Kay Kasemir reported:
I was always silently expecting that a record from a *.db file that
doesn't specifically list the DTYP would default to "Soft Channel".
Example:
record(ai, "XXX")
  field(INP, "SomeOtherRecord")
just works because the field DTYP="Soft Channel" is the default.
Now I notice that at least with R7.0.3.1, the default is not "Soft
Channel" but whatever is listed first in the *.dbd file. If that file
looks like this:
device(ai, CONSTANT, devAiSoft, "Soft Channel")
device(ai, INST_IO, devAiXXXX, "MyDeviceSupport")
then the default for an ai record DTYP is indeed "Soft Channel".
But if I put "MyDeviceSupport" on top, that becomes the default, as can
happen when you change the order of XXX_DBD file entries in the
Makefile.
** Affects: epics-base
     Importance: Medium
     Assignee: Andrew Johnson (anj)
         Status: In Progress
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1908305
Title:
Status in EPICS Base:
  In Progress
Bug description:
  Example:
  record(ai, "XXX")
  looks like this:
  can happen when you change the order of XXX_DBD file entries in the
  Makefile.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1908305/+subscriptions
[Bug 1908305] Re: Default DTYP can be changed by DBD file order Andrew Johnson via Core-talk
Prev: Jenkins build is back to normal : epics-pvAccess-mac #422 APS Jenkins via Core-talk
Next: [Bug 1908305] Re: Default DTYP can be changed by DBD file order Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: EPICS Web Site - Login Ralph Lange via Core-talk
ANJ, 16 Dec 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
