2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1908305] Re: Default DTYP can be changed by DBD file order
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 16 Dec 2020 05:12:21 -0000
See https://github.com/epics-base/epics-base/pull/96 for my proposed
fix.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1908305
Title:
Status in EPICS Base:
  In Progress
Bug description:
  Kay Kasemir reported:
  I was always silently expecting that a record from a *.db file that
  doesn't specifically list the DTYP would default to "Soft Channel".
  Example:
  record(ai, "XXX")
    field(INP, "SomeOtherRecord")
  just works because the field DTYP="Soft Channel" is the default.
  Now I notice that at least with R7.0.3.1, the default is not "Soft
  Channel" but whatever is listed first in the *.dbd file. If that file
  looks like this:
  device(ai, CONSTANT, devAiSoft, "Soft Channel")
  device(ai, INST_IO, devAiXXXX, "MyDeviceSupport")
  then the default for an ai record DTYP is indeed "Soft Channel".
  But if I put "MyDeviceSupport" on top, that becomes the default, as
  can happen when you change the order of XXX_DBD file entries in the
  Makefile.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1908305/+subscriptions
[Bug 1908305] [NEW] Default DTYP can be changed by DBD file order Andrew Johnson via Core-talk
Prev: [Bug 1908305] Re: Default DTYP can be changed by DBD file order Andrew Johnson via Core-talk
Next: [Bug 1908305] Re: Default DTYP can be changed by DBD file order Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 16 Dec 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
