2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: A general question about convert e.g. in longout record drvh, drvl handling
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Fri, 29 Jan 2021 16:29:08 +0000
I’m not convinced that any changes are really needed. I don’t want us to add another menu field for this, and I see Heinz’s somewhat unusual problem as a corner case that we have other ways to solve without changing the code.
Heinz, can you tell us whether my solution using IVOV or Ralph’s meets your needs please? I think we need to hear from you to stop alternative ideas from proliferating.
- Andrew
On Jan 29, 2021, at 10:19 AM, Ralph Lange via Core-talk <core-talk at aps.anl.gov> wrote:
On Fri, 29 Jan 2021 at 15:57, Ben Franksen via Core-talk <core-talk at aps.anl.gov> wrote:
Am 28.01.21 um 14:20 schrieb Zimoch Dirk (PSI) via Core-talk:
> One could of course change the check to if ((prec->drvl !=0 ||
> prec->drvh !=0) && prec->drvh > prec->drvl) But then in ao as well.
> It would change traditional behavior (which used to be documented
> wrongly in earlier EPICS releases) and potentially break existing
> IOCs where people use DLRH = DRVL != 0 and expect the limits to be
> ignored. It would also introduce a new "special case" because the
> record can then be fixed to any value except 0. Another option is to
> change the defaults from 0,0 to -verybig,+verybig.
> I think a poll would be needed.
-1
This makes a bad situation worse by complicating the rules. The problem
is the use of in-band exceptional values which is bad design and will
invariably hit you back sooner or later. Better fix: add a new field to
select whether to use or ignore DRVH/L.
To keep compatibility, that would have to be a menu AUTO/NO/YES with a default of AUTO.
Complexity comes for free, simplicity you have to work for.
Re: A general question about convert e.g. in longout record drvh, drvl handling Heinz Junkes via Core-talk
Re: A general question about convert e.g. in longout record drvh, drvl handling Ralph Lange via Core-talk
AW: A general question about convert e.g. in longout record drvh, drvl handling Zimoch Dirk (PSI) via Core-talk
Re: A general question about convert e.g. in longout record drvh, drvl handling Ben Franksen via Core-talk
Prev: [Bug 1913699] Re: vxWorks compilation fails with undeclared function Dirk Zimoch via Core-talk
Next: iocsh scripts and not using $PWD Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: A general question about convert e.g. in longout record drvh, drvl handling Ralph Lange via Core-talk
Next: Re: A general question about convert e.g. in longout record drvh, drvl handling Heinz Junkes via Core-talk
ANJ, 30 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
