2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: mp+394327 at code.launchpad.net
Date: Tue, 02 Feb 2021 19:06:31 -0000
Ok, maybe time to take a(nother) step back and ask if epicsMutexPriorityInversionTest should be run by default.
> testOk1( hiPriStalledTimeUs < 1000 );
This will almost certainly fail randomly with the CI builders since they don't have a PREEMPT_RT kernel, and are anyway timeshare VMs.
I don't see a need for Base to test whether PTHREAD_PRIO_INHERIT functions correctly.  This seems like testing malloc().  The critical question which a user will have is whether PTHREAD_PRIO_INHERIT is being set.  This seems more like asking whether OS priorities are being set at all.  This is complicated since, unlike priority or mlock(), I don't know of a straightforward way to verify this externally.  (I would resort to strace, which is complicated to interpret)
The question of OS priorities is answered by epicsThreadShowAll().  So maybe it would be sufficient for epicsMutexShowAll() to print a line showing if PTHREAD_PRIO_INHERIT is being set?
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 mdavidsaver via Core-talk
Next: [Bug 1913699] Re: vxWorks compilation fails with undeclared function Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 03 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
