2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1913699] Re: vxWorks compilation fails with undeclared function
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 02 Feb 2021 19:16:50 -0000
VxWorks 5.5.2, 6.8 and 6.9 all have close() defined in unistd.h. In the
VxWorks 6.x versions this header comment shows when they did that:
02w,31aug06,mwv  move kernel definitions of read(),write(),close()
                 to unistd.h (WIND00038902)
My Jenkins builds against 6.8 and 6.9 have not failed.
Dirk, which VxWorks version is this failing against? Do you have any
other local changes that are needed to support EPICS 7 on that version?
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1913699
Title:
Status in EPICS Base:
  New
Bug description:
  Since -Werror-implicit-function-declaration has been added to configure/CONFIG.gnuCommon in commit b49f0691, EPICS base 7.0 compilation fails for vxWorks in:
  ../osi/os/vxWorks/osdFindSymbol.c: In function `epicsLoadLibrary':
  ../osi/os/vxWorks/osdFindSymbol.c:49: error: implicit declaration of function `close'
  VxWorks declares close() in ioLib.h.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1913699/+subscriptions
[Bug 1913699] [NEW] vxWorks compilation fails with undeclared function Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: RT linux and priorities Konrad, Martin via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1913699] Re: vxWorks compilation fails with undeclared function mdavidsaver via Core-talk
Next: [Bug 1913699] Re: vxWorks compilation fails with undeclared function Dirk Zimoch via Core-talk
ANJ, 03 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
