2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1913699] Re: vxWorks compilation fails with undeclared function
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 03 Feb 2021 08:40:27 -0000
I have noticed that problem with vxWorks 6.3. I will check the other
versions I have available...
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1913699
Title:
Status in EPICS Base:
  New
Bug description:
  Since -Werror-implicit-function-declaration has been added to configure/CONFIG.gnuCommon in commit b49f0691, EPICS base 7.0 compilation fails for vxWorks in:
  ../osi/os/vxWorks/osdFindSymbol.c: In function `epicsLoadLibrary':
  ../osi/os/vxWorks/osdFindSymbol.c:49: error: implicit declaration of function `close'
  VxWorks declares close() in ioLib.h.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1913699/+subscriptions
[Bug 1913699] [NEW] vxWorks compilation fails with undeclared function Dirk Zimoch via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-138 AppVeyor via Core-talk
Next: [Bug 1913699] Re: vxWorks compilation fails with undeclared function Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1913699] Re: vxWorks compilation fails with undeclared function Andrew Johnson via Core-talk
ANJ, 03 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
