2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: CaSe-IndepeDent Menu SEARches?
From: Simon Rose via Core-talk <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>, Ralph Lange <ralph.lange at gmx.de>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Thu, 4 Feb 2021 16:18:50 +0000
On 2021-02-04, 16:43, "Core-talk on behalf of Michael Davidsaver via Core-talk" <core-talk-bounces at aps.anl.gov on behalf of core-talk at aps.anl.gov> wrote:
    > In such a tool, I would support and encourage all kinds of intelligent hints for improving databases, showing similar options for typos being the simplest example.
    > (What about "Engineers that used the calcout record also often use the seq and compress records.")
    > "Fixing" bugs on the fly? Rather not. Large blocks of explanations and suggestions on the IOC console? Rather not.
    Fair enough.  The are certainly diminishing returns for longer error messages.
There are diminishing returns for longer error messages, but it's still probably good to have more descriptive ones:
  Can't set "foo.SCAN" to "10 seconds" Extraneous characters
  Error at or before ")" in path "."  file "badchoice.db" line 2
  dbLoadRecords: failed to load 'badchoice.db'
  Error: Failed to load: badchoice.db
Doesn't tell you what the problem is or how to fix it, but
  Menu Choices:
     "Passive"
     "Event"
     "I/O Intr"
     "10 second"
     "5 second"
     "2 second"
     "1 second"
     ".5 second"
     ".2 second"
     ".1 second"
Or some variant does. But maybe a message such as 'Can't set "foo.SCAN" to "10 seconds" - invalid menu choice' could satisfy both criteria?
Cheers,
Simon Rose
Software Engineer
European Spallation Source
Re: CaSe-IndepeDent Menu SEARches? Michael Davidsaver via Core-talk
CaSe-IndepeDent Menu SEARches? Johnson, Andrew N. via Core-talk
Re: CaSe-IndepeDent Menu SEARches? Torsten Bögershausen via Core-talk
Re: CaSe-IndepeDent Menu SEARches? Ralph Lange via Core-talk
Prev: Re: Apple Silicon (Darwin-aarch64, arm64) for EPICS base Michael Davidsaver via Core-talk
Next: Re: CaSe-IndepeDent Menu SEARches? Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: CaSe-IndepeDent Menu SEARches? Michael Davidsaver via Core-talk
ANJ, 04 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
