2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: CaSe-IndepeDent Menu SEARches?
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: Simon Rose <Simon.Rose at ess.eu>, Ralph Lange <ralph.lange at gmx.de>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Thu, 4 Feb 2021 08:29:06 -0800
On 2/4/21 8:18 AM, Simon Rose wrote:
> On 2021-02-04, 16:43, "Core-talk on behalf of Michael Davidsaver via Core-talk" <core-talk-bounces at aps.anl.gov on behalf of core-talk at aps.anl.gov> wrote:
>     > In such a tool, I would support and encourage all kinds of intelligent hints for improving databases, showing similar options for typos being the simplest example.
>     > (What about "Engineers that used the calcout record also often use the seq and compress records.")
>     > "Fixing" bugs on the fly? Rather not. Large blocks of explanations and suggestions on the IOC console? Rather not.
>     Fair enough.  The are certainly diminishing returns for longer error messages.
> There are diminishing returns for longer error messages, but it's still probably good to have more descriptive ones:
>   Can't set "foo.SCAN" to "10 seconds" Extraneous characters
>   Error at or before ")" in path "."  file "badchoice.db" line 2
>   dbLoadRecords: failed to load 'badchoice.db'
>   Error: Failed to load: badchoice.db
> Doesn't tell you what the problem is or how to fix it, but
>   Menu Choices:
>      "Passive"
>      "Event"
>      "I/O Intr"
>      "10 second"
>      "5 second"
>      "2 second"
>      "1 second"
>      ".5 second"
>      ".2 second"
>      ".1 second"
> Or some variant does. But maybe a message such as 'Can't set "foo.SCAN" to "10 seconds" - invalid menu choice' could satisfy both criteria?
As background.  This specific error comes from trying to parse "10 seconds" as an integer
after failing to match any of the menu strings.  eg. "0" is the same as "Passive",
and "3" is "10 second".  Another possible error message is:
> Can't set "foo.SCAN" to "Pensive" No digits to convert
fyi. this is another actual typo for me.  The wonders of autocomplete...
Though I think pensive scans would be a good feature.
CaSe-IndepeDent Menu SEARches? Johnson, Andrew N. via Core-talk
Re: CaSe-IndepeDent Menu SEARches? Torsten Bögershausen via Core-talk
Re: CaSe-IndepeDent Menu SEARches? Ralph Lange via Core-talk
Re: CaSe-IndepeDent Menu SEARches? Michael Davidsaver via Core-talk
Re: CaSe-IndepeDent Menu SEARches? Simon Rose via Core-talk
Prev: Re: CaSe-IndepeDent Menu SEARches? Simon Rose via Core-talk
Next: Re: CaSe-IndepeDent Menu SEARches? Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
ANJ, 04 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
