2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~jeonghanlee/epics-base:darwin-aarch64 into epics-base:7.0
To: mp+397526 at code.launchpad.net
Date: Sat, 06 Feb 2021 04:23:40 -0000
> There are two outputs of `uname -ar` on the Apple M1. I can compile the EPICS
> base according to my shell environment, for example, Iterm2 and a terminal
> within the VS Code. The first one is the output of Iterm2 and the second is
> the output of the VS Code terminal.
> 1) Darwin JeongLee-M70.local 20.3.0 Darwin Kernel Version 20.3.0: Thu Jan 21
> 00:06:51 PST 2021; root:xnu-7195.81.3~1/RELEASE_ARM64_T8101 arm64
> 2) Darwin JeongLee-M70.local 20.3.0 Darwin Kernel Version 20.3.0: Thu Jan 21
> 00:06:51 PST 2021; root:xnu-7195.81.3~1/RELEASE_ARM64_T8101 x86_64
> Hope this help to your decision just in case.
Case 2) works with the current EPICS building system without any modification. And this branch is for Case 1).
https://code.launchpad.net/~jeonghanlee/epics-base/+git/epics-base/+merge/397526
Your team EPICS Core Developers is requested to review the proposed merge of ~jeonghanlee/epics-base:darwin-aarch64 into epics-base:7.0.
Re: [Merge] ~jeonghanlee/epics-base:darwin-aarch64 into epics-base:7.0 Jeong Han Lee via Core-talk
Prev: Build completed: epics-base base-menu-suggest-617 AppVeyor via Core-talk
Next: Re: [Merge] ~jeonghanlee/epics-base:darwin-aarch64 into epics-base:7.0 Han via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~jeonghanlee/epics-base:darwin-aarch64 into epics-base:7.0 Jeong Han Lee via Core-talk
ANJ, 07 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
