2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~jeonghanlee/epics-base:darwin-aarch64 into epics-base:7.0
To: mp+397526 at code.launchpad.net
Date: Sat, 06 Feb 2021 04:24:30 -0000
> There are a couple of typo's in here that I would clean up when merging; ppc
> is mentioned in a comment.
I only found one typo, if you let me know others, I can update the repo again.
> One thing I'd like to to discuss is whether we want to add another target for
> building universal binaries containing both x86 and arm code. The build system
> supported that for ppc+x86 (see configure/os/CONFIG_SITE.Common.darwin-ppcx86)
> so the same approach should still work for x86+arm, but we should probably use
> a more generic target name though, darwin-any, darwin-multi, darwin-all, ...?
https://code.launchpad.net/~jeonghanlee/epics-base/+git/epics-base/+merge/397526
Your team EPICS Core Developers is requested to review the proposed merge of ~jeonghanlee/epics-base:darwin-aarch64 into epics-base:7.0.
Prev: Re: [Merge] ~jeonghanlee/epics-base:darwin-aarch64 into epics-base:7.0 Han via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-144 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: [Merge] ~jeonghanlee/epics-base:darwin-aarch64 into epics-base:7.0 noreply--- via Core-talk
ANJ, 19 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
