2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Information request on RTEMS 4.10 needs/wants
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Gedare Bloom <gedare at rtems.org>
Cc: EPICS core-talk <core-talk at aps.anl.gov>, Joel Sherrill <joel at rtems.org>
Date: Thu, 11 Feb 2021 21:23:53 +0000
Hi Gedare,
On Feb 11, 2021, at 2:28 PM, Gedare Bloom via Core-talk <core-talk at aps.anl.gov> wrote:
There's a proposal that was floated 3 years ago and is recirculating
within the RTEMS development team to consider a long-term stable
branch of rtems-4.10. I'd like to gather some information about
possible interest or non-interest from EPICS. The key question is:
Would you like to include long-term stable 4.10 releases in any
open/maintained EPICS versions?
I can’t speak for other labs, but the APS at Argonne currently has around 100 RTEMS 4.9.2 and 4.10.2 uC5282 systems of several different types in our operational systems. Because of the limited size of that CPU board we don’t know whether those systems could be upgraded to RTEMS-5, and we don’t have the effort available right now to find out. As a result we want future EPICS releases to continue to build and run on RTEMS 4.10, and we have been contributing effort to ensure that EPICS will continue to work on 4.10 after we merge in the RTEMS-5 port. We haven’t needed to build newer RTEMS 4.10.x versions at APS, although I believe some other labs may have been using newer tagged versions.
Now speaking as an EPICS Core developer the EPICS CI process on GitHub Actions current runs our built-in unit tests against both 4.9 and 4.10 on i386 under qemu, and for RTEMS-5 we will test against i686 under qemu. We could add other architectures too if they can be made to run under qemu. The RTEMS builds that we use are compiled by Michael Davidsaver – we don’t try to use the latest RTEMS git version and I’m not sure exactly which tags his images were built against.
I will respond to your other email too…
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Information request on RTEMS 4.10 needs/wants Michael Davidsaver via Core-talk
Re: Information request on RTEMS 4.10 needs/wants Gedare Bloom via Core-talk
Prev: Information request on RTEMS 6+ needs/wants Gedare Bloom via Core-talk
Next: Re: Information request on RTEMS 6+ needs/wants Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Information request on RTEMS 4.10 needs/wants Gedare Bloom via Core-talk
Next: Re: Information request on RTEMS 4.10 needs/wants Michael Davidsaver via Core-talk
ANJ, 12 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
