2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Information request on RTEMS 4.10 needs/wants
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>, Gedare Bloom <gedare at rtems.org>
Cc: EPICS core-talk <core-talk at aps.anl.gov>, Joel Sherrill <joel at rtems.org>
Date: Thu, 11 Feb 2021 14:12:27 -0800
On 2/11/21 1:23 PM, Johnson, Andrew N. via Core-talk wrote:
> Now speaking as an EPICS Core developer the EPICS CI process on GitHub Actions current runs our built-in unit tests against both 4.9 and 4.10 on i386 under qemu, and for RTEMS-5 we will test against i686 under qemu. We could add other architectures too if they can be made to run under qemu. The RTEMS builds that we use are compiled by Michael Davidsaver – we don’t try to use the latest RTEMS git version and I’m not sure exactly which tags his images were built against.
For the past few years I've been publishing pre-built toolchains
for CI builders.  Practically this has meant building for some
version of Ubuntu.  So far this has been a mix of manual and
automatic processes due CI build time limits, changing CI environments,
as well as my own time constraints.
The result has been infrequent builds for a small number of BSPs.
https://github.com/mdavidsaver/rsb/releases
While I don't have a huge amount of time to spend on this, I am looking
at expanding this to the full list of BSPs with configuration in EPICS Base.
https://github.com/mdavidsaver/rsb/blob/ci/.github/workflows/ci-scripts-build.yml
I'd be thrilled to have some help with this.
Re: Information request on RTEMS 4.10 needs/wants Gedare Bloom via Core-talk
Re: Information request on RTEMS 4.10 needs/wants Johnson, Andrew N. via Core-talk
Prev: Re: Information request on RTEMS 6+ needs/wants Michael Davidsaver via Core-talk
Next: Re: Information request on RTEMS 6+ needs/wants Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Information request on RTEMS 4.10 needs/wants Johnson, Andrew N. via Core-talk
Next: Re: Information request on RTEMS 4.10 needs/wants Gedare Bloom via Core-talk
ANJ, 12 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
