2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: mp+399414 at code.launchpad.net
Date: Wed, 10 Mar 2021 16:57:39 -0000
Maybe the assumption is that a value borrowed from a record will never need cleanup?  Then:
1. type==dbfl_type_val && !dtor
2. type==dbfl_type_ref && dtor
3. type==dbfl_type_ref && !dtor
I'm not sure this is necessarily always true.  I've been toying with the idea of involving db_field_log in reference counting where a record and and some db_field_log would share ownership.  I haven't completely worked this through.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/399414
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Ben Franksen via Core-talk
ANJ, 10 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
