2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+399414 at code.launchpad.net
Date: Wed, 10 Mar 2021 08:08:22 -0000
Dirk Zimoch has proposed merging ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0.
Commit message:
Add filter to read info fields
Requested reviews:
  EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/399414
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0.
diff --git a/modules/database/src/std/filters/Makefile b/modules/database/src/std/filters/Makefile
index ee6a0ae..16e8171 100644
--- a/modules/database/src/std/filters/Makefile
+++ b/modules/database/src/std/filters/Makefile
@@ -16,6 +16,7 @@ dbRecStd_SRCS += dbnd.c
 dbRecStd_SRCS += arr.c
 dbRecStd_SRCS += sync.c
 dbRecStd_SRCS += decimate.c
+dbRecStd_SRCS += info.c
 HTMLS += filters.html
diff --git a/modules/database/src/std/filters/filters.dbd.pod b/modules/database/src/std/filters/filters.dbd.pod
index 27e356f..4503380 100644
--- a/modules/database/src/std/filters/filters.dbd.pod
+++ b/modules/database/src/std/filters/filters.dbd.pod
@@ -6,15 +6,17 @@ The following filters are available in this release:
 =over
-=item * L<TimeStamp|/"TimeStamp Filter ts">
+=item * L<TimeStamp|/TimeStamp Filter "ts">
-=item * L<Deadband|/"Deadband Filter dbnd">
+=item * L<Deadband|/Deadband Filter "dbnd">
-=item * L<Array|/"Array Filter arr">
+=item * L<Array|/Array Filter "arr">
-=item * L<Synchronize|/"Synchronize Filter sync">
+=item * L<Synchronize|/Synchronize Filter "sync">
-=item * L<Decimation|/"Decimation Filter dec">
+=item * L<Decimation|/Decimation Filter "dec">
+=item * L<Info Field|/Info Field Filter "info">
 =back
@@ -285,3 +287,35 @@ once every minute:
 =cut
+registrar(infoInitialize)
+=head3 Info Field Filter C<"info">
+This filter gives access to the info fields of a record.
+=head4 Parameters
+=over
+=item Name C<"name"> or C<"n">
+The name of the info field.
+=item Long String Flag C<"longstr"> or C<"l">
+If this optional flag is C<"yes">, C<"on">, or C<1>, the info field is returned
+as an array of C<CHAR>.
+If it is C<"no">, C<"off">, or C<0>, the info field is returned as a C<STRING>,
+truncated to 40 characters if necessary.
+The default is C<"auto">, which will use C<STRING> for sufficiently short values
+and array of C<CHAR> for long values.
+=back
+=head4 Example
+ $ caget 'test:channel.{"info":{"name":"infofield"}}
+ $ caget -S 'test:channel.{"info":{"name":"infofield","l":"yes"}}
+=cut
diff --git a/modules/database/src/std/filters/info.c b/modules/database/src/std/filters/info.c
new file mode 100644
index 0000000..2ec6a38
--- /dev/null
+++ b/modules/database/src/std/filters/info.c
@@ -0,0 +1,151 @@
+* Copyright (c) 2021 Paul Scherrer Institute
+* SPDX-License-Identifier: EPICS
+* EPICS BASE is distributed subject to a Software License Agreement found
+* in file LICENSE that is included with this distribution.
+ *  Author: Dirk Zimoch <dirk.zimoch at psi.ch>
+#include <stdio.h>
+#include <string.h>
+#include "chfPlugin.h"
+#include "dbStaticLib.h"
+#include "dbAccessDefs.h"
+#include "dbExtractArray.h"
+#include "db_field_log.h"
+#include "dbLock.h"
+#include "epicsExit.h"
+#include "freeList.h"
+#include "epicsExport.h"
+typedef struct myStruct {
+    char name[50];  /* arbitrary size, we better had dynamic strings */
+    DBENTRY dbentry;
+    int longstr;
+} myStruct;
+static void *myStructFreeList;
+static const
+chfPluginEnumType longstrEnum[] = {{"no",0}, {"off",0}, {"yes",1}, {"on",1}, {"auto",2}, {NULL, 0}};
+static const chfPluginArgDef opts[] = {
+    chfString (myStruct, name,    "name",    1, 0),
+    chfString (myStruct, name,    "n",       1, 0),
+    chfEnum   (myStruct, longstr, "longstr", 0, 1, longstrEnum),
+    chfEnum   (myStruct, longstr, "l",       0, 1, longstrEnum),
+    chfPluginArgEnd
+static void * allocPvt(void)
+    myStruct *my = (myStruct*) freeListCalloc(myStructFreeList);
+    if (!my) return NULL;
+    my->longstr = 2;
+    return (void *) my;
+static void freePvt(void *pvt)
+    freeListFree(myStructFreeList, pvt);
+static db_field_log* filter(void* pvt, dbChannel *chan, db_field_log *pfl)
+    myStruct *my = (myStruct*) pvt;
+    if (pfl->type == dbfl_type_ref && pfl->u.r.dtor)
+        pfl->u.r.dtor(pfl);
+    pfl->type = dbfl_type_ref;
+    pfl->u.r.dtor = NULL;
+    pfl->u.r.field = (void*)dbGetInfoString(&my->dbentry);
+    if (my->longstr) {
+        pfl->field_size = 1;
+        pfl->field_type = DBF_CHAR;
+        pfl->no_elements = strlen((char*)pfl->u.r.field)+1;
+    } else {
+        pfl->field_size = MAX_STRING_SIZE;
+        pfl->field_type = DBF_STRING;
+        pfl->no_elements = 1;
+    return pfl;
+static long channel_open(dbChannel *chan, void *pvt)
+    DBENTRY* pdbe = &my->dbentry;
+    int status;
+    dbInitEntryFromAddr(&chan->addr, pdbe);
+    for (status = dbFirstInfo(pdbe); !status; status = dbNextInfo(pdbe))
+        if (strcmp(dbGetInfoName(pdbe), my->name) == 0)
+            return 0;
+    return -1;
+static void channelRegisterPre(dbChannel *chan, void *pvt,
+    chPostEventFunc **cb_out, void **arg_out, db_field_log *pfl)
+    size_t len = strlen(dbGetInfoString(&my->dbentry)) + 1;
+    if (my->longstr == 2) {
+        my->longstr = len > MAX_STRING_SIZE;
+        pfl->no_elements = len;
+    } else {
+    *cb_out = filter;
+    *arg_out = pvt;
+static void channel_report(dbChannel *chan, void *pvt, int level,
+    const unsigned short indent)
+    printf("%*sInfo: name=%s\n", indent, "",
+           my->name);
+static chfPluginIf pif = {
+    allocPvt,
+    freePvt,
+    NULL, /* parse_error, */
+    NULL, /* parse_ok, */
+    channel_open,
+    channelRegisterPre,
+    NULL, /* channelRegisterPost, */
+    channel_report,
+    NULL /* channel_close */
+static void infoShutdown(void* ignore)
+    if(myStructFreeList)
+        freeListCleanup(myStructFreeList);
+    myStructFreeList = NULL;
+static void infoInitialize(void)
+    if (!myStructFreeList)
+        freeListInitPvt(&myStructFreeList, sizeof(myStruct), 64);
+    chfPluginRegister("info", &pif, opts);
+    epicsAtExit(infoShutdown, NULL);
+epicsExportRegistrar(infoInitialize);
Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Ben Franksen via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 mdavidsaver via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Ralph Lange via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Andrew Johnson via Core-talk
Prev: epics-pva2pva-linux32 - Build # 215 - Fixed! APS Jenkins via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Re: errlog.h Michael Davidsaver via Core-talk
ANJ, 11 Aug 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
