2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: mp+399414 at code.launchpad.net
Date: Wed, 10 Mar 2021 20:13:08 -0000
> ... What if two filters with dtors are chained?
Since the value is being replaced, the original dtor needs to be called.  So the basic process would be something like:
1. inspect previous value.  eg. copy/convert etc.
2. dtor previous value
3. copy in new value/pointer and install new dtor
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/399414
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Build failed: epics-base base-rtd-versioned-344 AppVeyor via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Ben Franksen via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 11 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
