2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1918909] [NEW] channel filters don't work wit PVA
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 12 Mar 2021 09:26:46 -0000
Public bug reported:
When using pvget with filters, only the number of elements is adjusted but not the data.
It works with Channel Access.
Example record:
record (aai, "TEST") {
field(FTVL, "SHORT")
field(NELM, "10")
field(INP, [9,8,7,6,5,4,3,2,1])
field(PINI, "YES")
info(test, "Hello World")
$ caget TEST TEST.{arr:{s:5}} TEST.{arr:{i:2}} 'TEST.{info:{n:"test"}}'
TEST 10 9 8 7 6 5 4 3 2 1 0
TEST.{arr:{s:5}} 5 4 3 2 1 0
TEST.{arr:{i:2}} 5 9 7 5 3 1
TEST.{info:{n:"test"}}         Hello World
$ pvget TEST TEST.{arr:{s:5}} TEST.{arr:{i:2}} 'TEST.{info:{n:"test"}}'
TEST                   2021-03-12 10:23:15.524  [9,8,7,6,5,4,3,2,1]
TEST.{arr:{s:5}}       2021-03-12 10:23:15.524  [9,8,7,6,5]
TEST.{arr:{i:2}}       2021-03-12 10:23:15.524  [9,8,7,6,5]
TEST.{info:{n:"test"}} 2021-03-12 10:23:15.524  9
** Affects: epics-base
     Importance: Undecided
         Status: New
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1918909
Title:
Status in EPICS Base:
  New
Bug description:
  Example record:
  field(NELM, "10")
  field(PINI, "YES")
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1918909/+subscriptions
[Bug 1918909] Re: channel filters don't work wit PVA mdavidsaver via Core-talk
[Bug 1918909] Re: channel filters don't work wit PVA Andrew Johnson via Core-talk
Prev: [Bug 1905159] Re: Fix warnings from recent compiler versions Gabriel Fedel via Core-talk
Next: Re: IPv6 Jeong Han Lee via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Build completed: EPICS Base 3.15 base-3.15-77 AppVeyor via Core-talk
Next: [Bug 1918909] Re: channel filters don't work wit PVA mdavidsaver via Core-talk
ANJ, 03 Jul 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
