2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1918909] Re: channel filters don't work wit PVA
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 12 Mar 2021 15:12:09 -0000
Transfer to https://github.com/epics-base/pva2pva/issues/41
** Bug watch added: github.com/epics-base/pva2pva/issues #41
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1918909
Title:
Status in EPICS Base:
  New
Bug description:
  When using pvget with filters, only the number of elements is adjusted but not the data.
  It works with Channel Access.
  Example record:
  record (aai, "TEST") {
  field(FTVL, "SHORT")
  field(NELM, "10")
  field(INP, [9,8,7,6,5,4,3,2,1])
  field(PINI, "YES")
  info(test, "Hello World")
  $ caget TEST TEST.{arr:{s:5}} TEST.{arr:{i:2}} 'TEST.{info:{n:"test"}}'
  TEST 10 9 8 7 6 5 4 3 2 1 0
  TEST.{arr:{s:5}} 5 4 3 2 1 0
  TEST.{arr:{i:2}} 5 9 7 5 3 1
  TEST.{info:{n:"test"}}         Hello World
  $ pvget TEST TEST.{arr:{s:5}} TEST.{arr:{i:2}} 'TEST.{info:{n:"test"}}'
  TEST                   2021-03-12 10:23:15.524  [9,8,7,6,5,4,3,2,1]
  TEST.{arr:{s:5}}       2021-03-12 10:23:15.524  [9,8,7,6,5]
  TEST.{arr:{i:2}}       2021-03-12 10:23:15.524  [9,8,7,6,5]
  TEST.{info:{n:"test"}} 2021-03-12 10:23:15.524  9
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1918909/+subscriptions
[Bug 1918909] [NEW] channel filters don't work wit PVA Dirk Zimoch via Core-talk
Prev: Re: Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?) Michael Davidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1918909] [NEW] channel filters don't work wit PVA Dirk Zimoch via Core-talk
Next: [Bug 1918909] Re: channel filters don't work wit PVA mdavidsaver via Core-talk
ANJ, 12 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
