2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-example-linux32 #865
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 14 Apr 2021 10:52:01 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-example-linux32/865/display/redirect>
Changes:
Started by upstream project "epics-pvDatabase-linux32" build number 498
originally caused by:
 Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on linux32-1 (linux32) in workspace <https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/>
The recommended git tool is: NONE
No credentials specified
 > git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url https://github.com/epics-base/exampleCPP.git # timeout=10
Cleaning workspace
 > git rev-parse --verify HEAD # timeout=10
Resetting working tree
 > git reset --hard # timeout=10
 > git clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/exampleCPP.git
 > git --version # timeout=10
 > git --version # 'git version 1.7.1'
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --progress https://github.com/epics-base/exampleCPP.git +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git rev-parse refs/remotes/origin/master^{commit} # timeout=10
Checking out Revision 0bd0b1c6b069b1ba6ec24ff4e00584aaa3b6a2d0 (refs/remotes/origin/master)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 0bd0b1c6b069b1ba6ec24ff4e00584aaa3b6a2d0 # timeout=10
Commit message: "Merge pull request #62 from epics-base/next_epics7_release"
 > git rev-list --no-walk 0bd0b1c6b069b1ba6ec24ff4e00584aaa3b6a2d0 # timeout=10
[epics-example-linux32] $ /bin/sh -xe /tmp/jenkins8429303010163100392.sh
+ echo 'PVDATABASE = /local/jenkins/workspace/epics-pvDatabase-linux32'
+ echo 'PVACLIENT = /local/jenkins/workspace/epics-pvaClient-linux32'
+ echo 'PVA2PVA = /local/jenkins/workspace/epics-pva2pva-linux32'
+ echo 'PVACCESS = /local/jenkins/workspace/epics-pvAccess-linux32'
+ echo 'NORMATIVE = /local/jenkins/workspace/epics-normativeTypes-linux32'
+ echo 'PVDATA = /local/jenkins/workspace/epics-pvData-linux32'
+ echo 'PVCOMMON = /local/jenkins/workspace/epics-pvCommon-linux32'
+ echo 'EPICS_BASE = /local/jenkins/workspace/epics-base-3.16-linux32'
+ make linux-x86
make -C ./configure linux-x86
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/configure'>
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/makeMakefile.pl O.linux-x86 ../..
mkdir -p O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/configure/O.linux-x86'>
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/convertRelease.pl checkRelease
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/configure/O.linux-x86'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/configure'>
make -C ./database linux-x86
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database'>
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/configure'>
mkdir -p O.Common
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/configure/O.linux-x86'>
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/configure/O.linux-x86'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/configure'>
make -C ./src linux-x86
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/src'>
mkdir -p O.Common
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/src/O.linux-x86'>
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF exampleHelloRPCClient.d  ../exampleHelloRPCClient.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF exampleSoftRecordRegister.d  ../exampleSoftRecordRegister.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF exampleDatabaseRegister.d  ../exampleDatabaseRegister.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF exampleDatabase.d  ../exampleDatabase.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF exampleHelloRPCRecord.d  ../exampleHelloRPCRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF exampleHelloRecord.d  ../exampleHelloRecord.cpp
Installing dbd file ../../dbd/exampleDatabaseRegister.dbd
mkdir ../../dbd
Installing dbd file ../../dbd/exampleSoftRecordRegister.dbd
Installing generic include file ../../include/pv/exampleHelloRecord.h
mkdir ../../include
mkdir ../../include/pv
Installing generic include file ../../include/pv/exampleHelloRPCRecord.h
Installing generic include file ../../include/pv/exampleDatabase.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -c ../exampleHelloRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -c ../exampleHelloRPCRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -c ../exampleDatabase.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -c ../exampleDatabaseRegister.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -c ../exampleSoftRecordRegister.cpp
/usr/bin/ar -rc    libexampleDatabase.a         exampleHelloRecord.o exampleHelloRPCRecord.o exampleDatabase.o exampleDatabaseRegister.o exampleSoftRecordRegister.o
/usr/bin/ranlib libexampleDatabase.a
/usr/bin/g++ -o libexampleDatabase.so.4.3.0 -shared -fPIC -Wl,-hlibexampleDatabase.so.4.3.0 -L<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/lib/linux-x86> -L/local/jenkins/workspace/epics-base-3.16-linux32/lib/linux-x86 -L/local/jenkins/workspace/epics-normativeTypes-linux32/lib/linux-x86 -L/local/jenkins/workspace/epics-pvAccess-linux32/lib/linux-x86 -L/local/jenkins/workspace/epics-pvData-linux32/lib/linux-x86 -L/local/jenkins/workspace/epics-pvDatabase-linux32/lib/linux-x86 -L/local/jenkins/workspace/epics-pvaClient-linux32/lib/linux-x86 -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/lib/linux-x86> -Wl,-rpath,/local/jenkins/workspace/epics-base-3.16-linux32/lib/linux-x86 -Wl,-rpath,/local/jenkins/workspace/epics-normativeTypes-linux32/lib/linux-x86 -Wl,-rpath,/local/jenkins/workspace/epics-pvAccess-linux32/lib/linux-x86 -Wl,-rpath,/local/jenkins/workspace/epics-pvData-linux32/lib/linux-x86 -Wl,-rpath,/local/jenkins/workspace/epics-pvDatabase-linux32/lib/linux-x86 -Wl,-rpath,/local/jenkins/workspace/epics-pvaClient-linux32/lib/linux-x86           -rdynamic -m32             exampleHelloRecord.o exampleHelloRPCRecord.o exampleDatabase.o exampleDatabaseRegister.o exampleSoftRecordRegister.o   -lpvDatabase -lpvaClient -lpvAccess -lpvAccessCA -lnt -lpvData -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../lib/linux-x86/libexampleDatabase.so.4.3.0
mkdir ../../lib
mkdir ../../lib/linux-x86
ln -s libexampleDatabase.so.4.3.0 ../../lib/linux-x86/libexampleDatabase.so
Installing library ../../lib/linux-x86/libexampleDatabase.a
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -c ../exampleHelloRPCClient.cpp
/usr/bin/g++ -o exampleHelloRPCClient  -L<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/lib/linux-x86> -L/local/jenkins/workspace/epics-base-3.16-linux32/lib/linux-x86 -L/local/jenkins/workspace/epics-normativeTypes-linux32/lib/linux-x86 -L/local/jenkins/workspace/epics-pvAccess-linux32/lib/linux-x86 -L/local/jenkins/workspace/epics-pvData-linux32/lib/linux-x86 -L/local/jenkins/workspace/epics-pvDatabase-linux32/lib/linux-x86 -L/local/jenkins/workspace/epics-pvaClient-linux32/lib/linux-x86 -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/lib/linux-x86> -Wl,-rpath,/local/jenkins/workspace/epics-base-3.16-linux32/lib/linux-x86 -Wl,-rpath,/local/jenkins/workspace/epics-normativeTypes-linux32/lib/linux-x86 -Wl,-rpath,/local/jenkins/workspace/epics-pvAccess-linux32/lib/linux-x86 -Wl,-rpath,/local/jenkins/workspace/epics-pvData-linux32/lib/linux-x86 -Wl,-rpath,/local/jenkins/workspace/epics-pvDatabase-linux32/lib/linux-x86 -Wl,-rpath,/local/jenkins/workspace/epics-pvaClient-linux32/lib/linux-x86           -rdynamic -m32            exampleHelloRPCClient.o    -lpvDatabase -lpvaClient -lpvAccess -lpvAccessCA -lnt -lpvData -lca -lCom
Installing created executable ../../bin/linux-x86/exampleHelloRPCClient
mkdir ../../bin
mkdir ../../bin/linux-x86
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/src/O.linux-x86'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/src'>
make -C ./ioc linux-x86
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/ioc'>
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/ioc/src'>
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/makeMakefile.pl O.linux-x86 ../../..
mkdir -p O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/ioc/src/O.linux-x86'>
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../../../dbd -I/local/jenkins/workspace/epics-pvDatabase-linux32/dbd -I/local/jenkins/workspace/epics-pva2pva-linux32/dbd -I/local/jenkins/workspace/epics-pvAccess-linux32/dbd -I/local/jenkins/workspace/epics-base-3.16-linux32/dbd -o simpleBusyRecord.h ../simpleBusyRecord.dbd
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../../../dbd -I/local/jenkins/workspace/epics-pvDatabase-linux32/dbd -I/local/jenkins/workspace/epics-pva2pva-linux32/dbd -I/local/jenkins/workspace/epics-pvAccess-linux32/dbd -I/local/jenkins/workspace/epics-base-3.16-linux32/dbd -o charoutRecord.h ../charoutRecord.dbd
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../../../dbd -I/local/jenkins/workspace/epics-pvDatabase-linux32/dbd -I/local/jenkins/workspace/epics-pva2pva-linux32/dbd -I/local/jenkins/workspace/epics-pvAccess-linux32/dbd -I/local/jenkins/workspace/epics-base-3.16-linux32/dbd -o shortoutRecord.h ../shortoutRecord.dbd
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../../../dbd -I/local/jenkins/workspace/epics-pvDatabase-linux32/dbd -I/local/jenkins/workspace/epics-pva2pva-linux32/dbd -I/local/jenkins/workspace/epics-pvAccess-linux32/dbd -I/local/jenkins/workspace/epics-base-3.16-linux32/dbd -o ucharoutRecord.h ../ucharoutRecord.dbd
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../../../dbd -I/local/jenkins/workspace/epics-pvDatabase-linux32/dbd -I/local/jenkins/workspace/epics-pva2pva-linux32/dbd -I/local/jenkins/workspace/epics-pvAccess-linux32/dbd -I/local/jenkins/workspace/epics-base-3.16-linux32/dbd -o ushortoutRecord.h ../ushortoutRecord.dbd
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../../../dbd -I/local/jenkins/workspace/epics-pvDatabase-linux32/dbd -I/local/jenkins/workspace/epics-pva2pva-linux32/dbd -I/local/jenkins/workspace/epics-pvAccess-linux32/dbd -I/local/jenkins/workspace/epics-base-3.16-linux32/dbd -o ulongoutRecord.h ../ulongoutRecord.dbd
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../../../dbd -I/local/jenkins/workspace/epics-pvDatabase-linux32/dbd -I/local/jenkins/workspace/epics-pva2pva-linux32/dbd -I/local/jenkins/workspace/epics-pvAccess-linux32/dbd -I/local/jenkins/workspace/epics-base-3.16-linux32/dbd -o floatoutRecord.h ../floatoutRecord.dbd
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF floatoutRecord.d  ../floatoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF ulongoutRecord.d  ../ulongoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF ushortoutRecord.d  ../ushortoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF ucharoutRecord.d  ../ucharoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF shortoutRecord.d  ../shortoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF charoutRecord.d  ../charoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF simpleBusyRecord.d  ../simpleBusyRecord.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF exampleDatabaseMain.d  ../exampleDatabaseMain.cpp
Expanding dbd file ../exampleDatabaseInclude.dbd
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/local/jenkins/workspace/epics-pvDatabase-linux32/dbd -I/local/jenkins/workspace/epics-pva2pva-linux32/dbd -I/local/jenkins/workspace/epics-pvAccess-linux32/dbd -I/local/jenkins/workspace/epics-base-3.16-linux32/dbd -o exampleDatabase.dbd ../exampleDatabaseInclude.dbd
dbdExpand.pl: Can't find file 'pvdbSpecialRegister.dbd'
  while reading '../exampleDatabaseInclude.dbd' to create 'exampleDatabase.dbd'
dbdExpand.pl: Exiting due to errors
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES.Db:385: recipe for target '../O.Common/exampleDatabase.dbd' failed
make[4]: *** [../O.Common/exampleDatabase.dbd] Error 2
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/ioc/src/O.linux-x86'>
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_ARCHS:62: recipe for target 'linux-x86' failed
make[3]: *** [linux-x86] Error 2
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/ioc/src'>
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_DIRS:84: recipe for target 'src.linux-x86' failed
make[2]: *** [src.linux-x86] Error 2
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/ioc'>
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_DIRS:84: recipe for target 'ioc.linux-x86' failed
make[1]: *** [ioc.linux-x86] Error 2
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database'>
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_DIRS:84: recipe for target 'database.linux-x86' failed
make: *** [database.linux-x86] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: test/O.*/*.tap
Did not find any matching files.
Jenkins build is back to normal : epics-example-linux32 #866 APS Jenkins via Core-talk
Build failed in Jenkins: epics-example-linux32 #864 APS Jenkins via Core-talk
Prev: Windows paths inside iocShell Ralph Lange via Core-talk
Next: Re: [EXTERNAL] Windows paths inside iocShell Kasemir, Kay via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-example-linux32 #864 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-example-linux32 #866 APS Jenkins via Core-talk
ANJ, 18 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
