2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Windows paths inside iocShell
From: "Kasemir, Kay via Core-talk" <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>, Ralph Lange <ralph.lange at gmx.de>
Date: Wed, 14 Apr 2021 15:57:23 +0000
I vaguely remember that inside code, like when calling 'open()' on a file, Windows handles /forward/slash/paths just fine, as it does handle c:\those\backslash\paths. But a path that combines / and \ might be problematic.
If you manually set
epicsEnvSet FOO  "C:\Users\nobody\AppData\Roaming/foobar"
does that actually work?
Or are the macro issues just part of the problem, the combined / and \ will be the next one?
Would a better workaround in this case be to define %APPDATA% with forward slashes?
Or in case %APPDATA% is some predefined variable, introduce your own variable?
Under Windows, using system environment variables containing paths in the iocShell doesn't work, because backslash characters (\) in the path are interpreted as the first character of an escape sequence.
Example. Trying to set a location inside %AppData% by doing
epicsEnvSet FOO ${APPDATA}/foobar
creates an invalid path, because the backslashes disappear:
C:UsersnobodyAppDataRoaming/foobar
Shouldn't backslashes rather be treated verbatim here?
The expansion is done by macLib before the epicsEnvSet command is being called. Do we need a modifier that allows verbatim macro replacement? The getenv() used by macLib converts '\' to '\\' when reading from the environment, but macLib seems to resolve (discard) the "escape sequence" further down in the process.
Re: [EXTERNAL] Windows paths inside iocShell Ralph Lange via Core-talk
Prev: Build failed in Jenkins: epics-example-linux32 #865 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-example #727 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Windows paths inside iocShell Ralph Lange via Core-talk
Next: Re: [EXTERNAL] Windows paths inside iocShell Ralph Lange via Core-talk
ANJ, 14 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
