2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Windows paths inside iocShell
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Wed, 14 Apr 2021 16:56:26 +0000
Hi Ralph,
On Apr 14, 2021, at 11:13 AM, Ralph Lange via Core-talk <core-talk at aps.anl.gov> wrote:
> AppData is one of quite a few standard Windows variables. Obviously, introducing my own variables would work and make the whole thing non-portable.
> The getenv() call works just fine, mixed paths work fine, I can read directly from the environment and have utilities that convert forward to backslashes etc etc.
> The one and only real show stopper is that the iocShell's macro expansion changes the value of those standard environment variables when you use them.
Even epicsEnvSet preserves back-slashes in the values it sets. The macLib routines are supposed to preserve strings inside single quotes, but then they don’t expand the macros inside. I just experimented with various ways of quoting stuff, but that doesn’t seem to help at all:
> epics> epicsEnvShow APPDATA
> APPDATA=C:\Users\jenkins\AppData\Roaming
> epics> echo $(APPDATA)
> C:UsersjenkinsAppDataRoaming
> epics> echo "$(APPDATA)”
> epics> echo '$(APPDATA)'
> $(APPDATA)
> epics> epicsEnvSet q "'"
> epics> epicsEnvShow q
> q='
> epics> echo $(q)$(APPDATA)$(q)
> epics> echo "$(q)$(APPDATA)$(q)"
> epics> epicsEnvSet eq "\'"
> epics> epicsEnvShow eq
> eq=\'
> epics> echo "$(eq)$(APPDATA)$(eq)"
> 'C:UsersjenkinsAppDataRoaming'
> epics> epicsEnvSet d '"'
> epics> epicsEnvShow d
> d="
> epics> echo "$(d)$(APPDATA)$(d)"
> epics> epicsEnvSet b "\"
> epics> epicsEnvShow b
> b=\
> epics> echo "$(b)$(APPDATA)$(b)"
> epics> epicsEnvSet bb "\\"
> epics> epicsEnvShow bb
> bb=\\
> epics> echo "$(bb)$(APPDATA)$(bb)"
> epics> epicsEnvSet bbb "\\\"
> epics> epicsEnvShow bbb
> bbb=\\\
> epics> echo "$(bbb)$(APPDATA)$(bbb)"
> \C:UsersjenkinsAppDataRoaming\
> epics> epicsEnvSet ed '\"'
> epics> epicsEnvShow ed
> ed=\"
> epics> echo "$(ed)$(APPDATA)$(ed)"
> epics> epicsEnvSet eeq "\\'"
> epics> epicsEnvShow eeq
> eeq=\\'
> epics> echo "$(eeq)$(APPDATA)$(eeq)"
> epics> epicsEnvSet eeeq "\\\'"
> epics> epicsEnvShow eeeq
> eeeq=\\\'
> epics> echo "$(eeeq)$(APPDATA)$(eeeq)"
> 'C:UsersjenkinsAppDataRoaming’
> epics> epicsEnvSet eed '\\"'
> epics> epicsEnvShow eed
> eed=\\"
> epics> echo "$(eed)$(APPDATA)$(eed)"
> epics> epicsEnvSet eeed '\\\"'
> epics> epicsEnvShow eeed
> eeed=\\\"
> epics> echo "$(eeed)$(APPDATA)$(eeed)"
> Unbalanced quote.
That last error (from iocsh, not macLib) is interesting, but probably not useful.
Do we need some syntax in macros to prevent them from escaping back-slashes when expanding values?  I’m not sure how easy it would be to implement that, but it might be possible. Any other suggestions on what might be changed?
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: [EXTERNAL] Windows paths inside iocShell Ralph Lange via Core-talk
Re: [EXTERNAL] Windows paths inside iocShell Kasemir, Kay via Core-talk
Prev: Build failed in Jenkins: epics-example-win64 #664 APS Jenkins via Core-talk
Next: Re: [EXTERNAL] Windows paths inside iocShell Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Windows paths inside iocShell Ralph Lange via Core-talk
ANJ, 14 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
