2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+366247 at code.launchpad.net
Date: Wed, 28 Apr 2021 13:19:11 -0000
The specific breakage was: Changing calcout.INPx to a differenct constant does not work any longer.
The application is a user configureable calc where the users enter CALC and set INPx fields to other records or to constants on the fly. The very use case this fix has been made for. Thus I guess it will work, but before trying it, I wanted to know why it is on hold (priority "high", "In Progress", "needs fixing") for so long. Any severe doubts that it will work?
https://code.launchpad.net/~anj/epics-base/+git/base-7.0/+merge/366247
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Build failed: EPICS Base 7 base-7.0-311 AppVeyor via Core-talk
Next: Problem building NDPluginPVA on base 7.0.5 Mark Rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 29 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
