2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+366247 at code.launchpad.net
Date: Thu, 29 Apr 2021 07:21:26 -0000
I had re-based the change onto the latest 7.0 yesterday, including resolving the conflict in dbAccess.c which came from the change to use dbChannel.I have addressed the issue Michael mentioned:
"Good practice might be to set 'pdbaddr=NULL' when it is consumed by dbAddLink(), then add a 'free(pdbaddr)' to the cleanup step. Also need to make dbAddLink() free it on error."
I already did exactly that when changing dbAccess to used dbChannel and resolved that now in the merge.
It builds and fixes the problem with calcout. Of course it does not magically provide the same feature to all other records, e.g. calc. I still have to understand why the changes in *SoftCallback supports are needed.
https://code.launchpad.net/~anj/epics-base/+git/base-7.0/+merge/366247
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Re: Problem building NDPluginPVA on base 7.0.5 Simon Rose via Core-talk
Next: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 29 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
