2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: CA incompatibilities?
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Dirk Zimoch <dirk.zimoch at psi.ch>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Tue, 15 Jun 2021 16:37:01 +0000
On Jun 15, 2021, at 11:20 AM, Michael Davidsaver via Core-talk <core-talk at aps.anl.gov> wrote:
On 6/15/21 8:39 AM, Zimoch Dirk (PSI) via Core-talk wrote:
One of my customers complained that his EPICS 3.13.2 client cannot connect any longer since the IOC has been upgraded
from 3.14.12 to 7.0.5.
I checked and 'caget' from the current 3.14 works with 'softIoc' from current 7.0.
(Don't tell me that  he should upgrade, please.)
I won't tell you that he _must_ upgrade, but I will certainly say that he _should_.
An alternative solution which one of our beamlines uses for a similar kind of problem would be for him to run a CA Gateway (built with Base 3.15.x) on the machine that his client runs on, with its server side listening on localhost. Then you configure his client to run with EPICS_CA_ADDR_LIST pointed to localhost and set AUTO_ADDR_LIST to NO, so all of its IOC traffic goes through the gateway.
- Andrew
Complexity comes for free, simplicity you have to work for.
CA incompatibilities? Zimoch Dirk (PSI) via Core-talk
Re: CA incompatibilities? Michael Davidsaver via Core-talk
Prev: Re: CA incompatibilities? Michael Davidsaver via Core-talk
Next: [Bug 1932033] Re: base EPICS compilation misses convertRelease.pl Jerzy Tarasiuk via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: CA incompatibilities? Mark Rivers via Core-talk
ANJ, 15 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
