2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: CA incompatibilities?
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>, Michael Davidsaver <mdavidsaver at gmail.com>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Tue, 15 Jun 2021 17:25:02 +0000
The report I received (indirectly) from the NSLS-II controls group was:
"The new EPICS version on the IOC server will not process
CA_PROTO_SEARCH request without first seeing a CA_PROTO_VERSION
request (CA protocol actually requires this). The IDL packets do not
contain the required CA_PROTO_VERSION (16 bytes)."
Does this make sense in terms of IDL being built with an old version of base?
From: Core-talk <core-talk-bounces at aps.anl.gov> on behalf of Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
Sent: Tuesday, June 15, 2021 11:20 AM
To: Zimoch Dirk (PSI)
Cc: core-talk at aps.anl.gov
On 6/15/21 8:39 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> One of my customers complained that his EPICS 3.13.2 client cannot connect any longer since the IOC has been upgraded
> from 3.14.12 to 7.0.5.
I checked and 'caget' from the current 3.14 works with 'softIoc' from current 7.0.
> (Don't tell me that  he should upgrade, please.)
I won't tell you that he _must_ upgrade, but I will certainly say that he _should_.
> Searching the release notes, I found that support for clients < V4 (< EPICS R3.12.0-beta1) are not supported any longer
> since 3.16.1. But the client is question reports V4.8.
> Was there another CA compatibility drop since 3.16.1?
No.  Though, my change which dropped support for < 3.12 actually seems
to have dropped support for < 3.13.  I have no way to test anything
before 3.14, so I'm not certain of this.
https://github.com/epics-base/epics-base/pull/141#discussion_r602439829
While I don't anticipate any further deprecation of older CA protocol
versions, it should be noted that interoperability with older versions
is getting little to no testing.  It is inevitable that regressions
will creep in unless those with a continuing interest regularly test
the latest developments with these oldest versions.
Re: CA incompatibilities? Michael Davidsaver via Core-talk
CA incompatibilities? Zimoch Dirk (PSI) via Core-talk
Prev: [Bug 1932033] Re: base EPICS compilation misses convertRelease.pl Jerzy Tarasiuk via Core-talk
Next: Re: CA incompatibilities? Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: CA incompatibilities? Johnson, Andrew N. via Core-talk
ANJ, 15 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
