2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1939568] Re: Writing to mbboDirect.VAL does not work any more in EPICS >= 3.15
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 13 Aug 2021 17:03:17 -0000
> The special() function could update the time stamp before posting the
monitors.
True, but then a record's timestamp no longer tells you if/when it was
last processed. We used to tell people to check UDF for that, currently
we say to check the timestamp.
A few other record-types also call db_post_events() from their special()
routines without getting a new timestamp: calcout, mbbi, mbbo
The mbboDirect::special() doesn't call db_post_events() when it updates
VAL. That would raise questions about updating MLST as well, and what to
do about alarms – calling monitor() isn't right either...
I suspect this discussion is just widening the cracks in our abstraction
that is the IOC's record model. Unless somebody else has any other
bright ideas I'll just add the special(SPC_RESET) as proposed and stop
there.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1939568
Title:
Status in EPICS Base:
  New
Bug description:
  In EPICS 3.14, it was possible to write to mbboDirect.VAL. This does not work any longer with EPICS 3.15 or higher.
  However, writing to .VAL was always buggy anyway (did not update the.Bx fields).
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1939568/+subscriptions
[Bug 1939568] [NEW] Writing to mbboDirect.VAL does not work any more in EPICS 7 Dirk Zimoch via Core-talk
Prev: [Bug 1939568] Re: Writing to mbboDirect.VAL does not work any more in EPICS >= 3.15 Dirk Zimoch via Core-talk
Next: [Bug 1939568] Re: Writing to mbboDirect.VAL does not work any more in EPICS >= 3.15 Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
ANJ, 13 Aug 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
