2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1939568] Re: Writing to mbboDirect.VAL does not work any more in EPICS >= 3.15
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 13 Aug 2021 17:31:19 -0000
I remember my (failed) fight for having a timestamp in the event update
that shows when the value changed - instead of or in addition to the
timestamp that shows when the record processed...
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1939568
Title:
Status in EPICS Base:
  New
Bug description:
  In EPICS 3.14, it was possible to write to mbboDirect.VAL. This does not work any longer with EPICS 3.15 or higher.
  However, writing to .VAL was always buggy anyway (did not update the.Bx fields).
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1939568/+subscriptions
[Bug 1939568] [NEW] Writing to mbboDirect.VAL does not work any more in EPICS 7 Dirk Zimoch via Core-talk
Prev: [Bug 1939568] Re: Writing to mbboDirect.VAL does not work any more in EPICS >= 3.15 Andrew Johnson via Core-talk
Next: epics-7.0 » linux32 - Build # 355 - Unstable! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: [Bug 1939568] Re: Writing to mbboDirect.VAL does not work any more in EPICS >= 3.15 mdavidsaver via Core-talk
ANJ, 01 Sep 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
