2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Bug 1935037] Re: Invalid charactor in field name
From: Niko Kivel via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 26 Aug 2021 17:50:02 -0000
If this limitation stays like that, it's a complete show-stopper for me.
I'd like to create structures for EtherCAT terminal/slave data. There are
potentially hundreds of PVs to add to pva-groups. All based on their PV
names. Since the PV names have to adhere to the naming convention, they
have '-' between entity name and suffix, i.e. BI02-TimeRise,
master7-Online, BO03-Array, ...
Proposal:
I'd be perfectly happy with a replacement mechanism. I.e. upon adding a PV
to the group, replace non-supported characters with '_'.
Maybe with a flag to prevent automatic conversion? And cause the Error to
be thrown?
On Thu, Aug 26, 2021 at 6:25 PM mdavidsaver <1935037 at bugs.launchpad.net>
wrote:
> The character set restriction of PVD fields (in groups or otherwise) is
> meant to mirror that of C89 keywords.
> > int abc;
> ... is valid
> > int a-bc;
> ... is not
> This was a somewhat arbitrary decision made many years ago.  imo.
> changing it is primarily a question of backwards compatibility.
> Anything rejected by (or crashing) existing/older clients is a non-
> starter.
> Be aware that there is no separate versioning for the PVD encoding.
> imo. an oversight in the design.  The negotiated PVA protocol version is
> the only way to communicate handle changes.  You should also be aware
> that the existing pvData (de)serialization APIs don't expose the
> negotiated protocol version.  So making even seemingly small changes to
> the PVD encoding format would be complicated.
> You received this bug notification because you are subscribed to the bug
> report.
> https://bugs.launchpad.net/bugs/1935037
> Title:
> Status in EPICS Base:
>   New
> Bug description:
>   When creating a group in QSRV, the allowed characters are too
>   restrictive
>   error:
>   Error Group not created: Invalid charactor '-' (45) in field name
> "BI02-TimeRise" must be A-Z, a-z, 0-9, or '_'
>   expected behaviour:
>   pva structures should allow for a more liberal set of characters that
> just what is covered by \w regex metacharacter.
> To manage notifications about this bug go to:
> https://bugs.launchpad.net/epics-base/+bug/1935037/+subscriptions
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
Title:
  New
Bug description:
  restrictive
  error:
  Error Group not created: Invalid charactor '-' (45) in field name "BI02-TimeRise" must be A-Z, a-z, 0-9, or '_'
  expected behaviour:
  pva structures should allow for a more liberal set of characters that just what is covered by \w regex metacharacter.
[Bug 1935037] [NEW] Invalid charactor in field name Niko Kivel via Core-talk
[Bug 1935037] Re: Invalid charactor in field name mdavidsaver via Core-talk
Prev: [Bug 1935037] Re: Invalid charactor in field name mdavidsaver via Core-talk
Next: [Bug 1935037] Re: Invalid charactor in field name Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: [Bug 1935037] Re: Invalid charactor in field name mdavidsaver via Core-talk
ANJ, 27 Aug 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
