2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1935037] Re: Invalid charactor in field name
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 27 Aug 2021 07:34:57 -0000
I would prefer to traverse the "normal" structure way with '.' instead of '->'.
In particular as using '.' in qsrv creates a structure (with char restriction removed from validateFieldName):
    info(Q:group, {
        "PV" : {
            "my.field": {+type:plain, +channel:VAL},
            "my.other-field": {+type:plain, +channel:VAL},
$ pvget PV
PV structure
    structure record
        structure _options
            uint queueSize 0
            boolean atomic true
    structure my
        double field 0
        double other-field 0
Being able to access the fields in a simple way would be nice:
$ pvget PV.my.other-field
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1935037
Title:
Status in EPICS Base:
  New
Bug description:
  When creating a group in QSRV, the allowed characters are too
  restrictive
  error:
  Error Group not created: Invalid charactor '-' (45) in field name "BI02-TimeRise" must be A-Z, a-z, 0-9, or '_'
  expected behaviour:
  pva structures should allow for a more liberal set of characters that just what is covered by \w regex metacharacter.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1935037/+subscriptions
[Bug 1935037] [NEW] Invalid charactor in field name Niko Kivel via Core-talk
Prev: Re: [Bug 1935037] Re: Invalid charactor in field name Niko Kivel via Core-talk
Next: [Bug 1935037] Re: Invalid charactor in field name Timo Korhonen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1935037] Re: Invalid charactor in field name mdavidsaver via Core-talk
ANJ, 27 Aug 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
