2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: CA gateway chaining
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Dirk Zimoch <dirk.zimoch at psi.ch>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Mon, 25 Oct 2021 16:32:03 +0000
On Oct 25, 2021, at 3:53 AM, Zimoch Dirk (PSI) via Core-talk <core-talk at aps.anl.gov> wrote:
We have seen load related effects. In particular loading the gateway with arrays "freezes" the monitors on scalar
values. Recent observations with camera IOCs suggest that this is not gateway specific. Somewhere in CA monitors on
arrays seem to get higher priority than scalars. No idea where.
I’m not sure that arrays really get higher priority anywhere, but once the CA server has started to put an array value onto the wire it can’t be interrupted with updates from any other channels until every TCP packet holding that array data has been sent out. I believe (but I might be wrong) the CA gateway has a single-threaded server side, so sending a single large array through it will hold up every other channel that wants to pass through the gateway at the same time even if the two end-points are completely unrelated to the array channel.
IIRC the PVA protocol and gateway were designed to be a lot more efficient at handling large amounts of array data, which is why I would recommend using PVA for areaDetector transport.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: CA gateway chaining Kasemir, Kay via Core-talk
CA gateway chaining Timo Korhonen via Core-talk
Re: CA gateway chaining Zimoch Dirk (PSI) via Core-talk
Prev: Re: [EXTERNAL] CA gateway chaining Hartman, Steven via Core-talk
Next: Re: CA gateway chaining Kasemir, Kay via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: CA gateway chaining Timo Korhonen via Core-talk
ANJ, 25 Oct 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
