2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: CA gateway chaining
From: "Kasemir, Kay via Core-talk" <core-talk at aps.anl.gov>
To: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Mon, 25 Oct 2021 17:14:44 +0000
> I’m not sure that arrays really get higher priority anywhere...
Some CA clients (CS-Studio) will in fact create the Channel Access channel for arrays at a _lower​_ priority than scalar channels. I believe this was originally implemented for BNL to lessen IOC CPU load.
>IIRC the PVA protocol and gateway were designed to be a lot more efficient at handling large amounts of array data, which is why I would recommend using PVA for areaDetector transport.
The numerous CA gateways used on SNS beamline and the concentrator gateway that Steven just mentioned limit the EPICS_CA_MAX_ARRAY_BYTES because otherwise one remote user looking at a large array (image) would halt updates for everybody else's screen.
The PVA implementations try to offer "fair scheduling" which Michael once described as trading throughput in favor of latency, ie. throughput may be reduced, but latency should also be reduced. At this time I don't have operational experience with it, but a first test of the latest PVA gateway, https://mdavidsaver.github.io/p4p/gw.html, indeed passes area detector images from the sim detector. Unclear how to quantify, but a basic test of looking at scalars via the PVA gateway and then opening an area detector image display didn't result in the same severe delays of the scalars in the way usually seen with the CA gateway.
-Kay
CA gateway chaining Timo Korhonen via Core-talk
Re: CA gateway chaining Zimoch Dirk (PSI) via Core-talk
Re: CA gateway chaining Johnson, Andrew N. via Core-talk
Prev: Re: CA gateway chaining Johnson, Andrew N. via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-417 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: [EXTERNAL] CA gateway chaining Hartman, Steven via Core-talk
ANJ, 25 Oct 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
