2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: 3.15-pva2pva-win64 #344
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sat, 27 Nov 2021 16:27:25 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/3.15-pva2pva-win64/344/display/redirect>
Changes:
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on win64-2 (windows-x64) in workspace <https://jenkins.aps.anl.gov/job/3.15-pva2pva-win64/ws/>
The recommended git tool is: NONE
No credentials specified
 > C:/Program Files/Git/cmd/git.exe rev-parse --resolve-git-dir C:\jenkins\win64-2\workspace\3.15-pva2pva-win64\.git # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files/Git/cmd/git.exe config remote.origin.url https://github.com/epics-base/pva2pva.git # timeout=10
Cleaning workspace
 > C:/Program Files/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
 > C:/Program Files/Git/cmd/git.exe reset --hard # timeout=10
 > C:/Program Files/Git/cmd/git.exe clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/pva2pva.git
 > C:/Program Files/Git/cmd/git.exe --version # timeout=10
 > git --version # 'git version 2.20.1.windows.1'
Setting http proxy: webproxy1.anl.gov:9091
 > C:/Program Files/Git/cmd/git.exe fetch --tags --force --progress -- https://github.com/epics-base/pva2pva.git +refs/heads/*:refs/remotes/origin/* # timeout=10
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from https://github.com/epics-base/pva2pva.git
	at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1001)
	at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1242)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1302)
	at hudson.scm.SCM.checkout(SCM.java:505)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1213)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:643)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:85)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:515)
	at hudson.model.Run.execute(Run.java:1888)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:99)
	at hudson.model.Executor.run(Executor.java:432)
Caused by: hudson.plugins.git.GitException: Command "C:/Program Files/Git/cmd/git.exe fetch --tags --force --progress -- https://github.com/epics-base/pva2pva.git +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: remote: Internal Server Error.
remote:
fatal: unable to access 'https://github.com/epics-base/pva2pva.git/': The requested URL returned error: 500
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2681)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:2102)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$500(CliGitAPIImpl.java:86)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:624)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:160)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:153)
	at hudson.remoting.UserRequest.perform(UserRequest.java:211)
	at hudson.remoting.UserRequest.perform(UserRequest.java:54)
	at hudson.remoting.Request$2.run(Request.java:376)
	at hudson.remoting.InterceptingExecutorService.lambda$wrap$0(InterceptingExecutorService.java:78)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
	Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to win64-2
		at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1797)
		at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:356)
		at hudson.remoting.Channel.call(Channel.java:1001)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:145)
		at sun.reflect.GeneratedMethodAccessor941.invoke(Unknown Source)
		at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
		at java.lang.reflect.Method.invoke(Method.java:498)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:131)
		at com.sun.proxy.$Proxy98.execute(Unknown Source)
		at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:999)
Jenkins build is back to normal : 3.15-pva2pva-win64 #345 APS Jenkins via Core-talk
Prev: Jenkins build is back to normal : epics-normativeTypes-win64 #532 APS Jenkins via Core-talk
Next: Build failed in Jenkins: 3.15-pva2pva-win64s #333 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : 3.15-pvaClient-win64s #354 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : 3.15-pva2pva-win64 #345 APS Jenkins via Core-talk
ANJ, 06 Dec 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
