2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: 3.15-pva2pva-win64s #333
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sat, 27 Nov 2021 16:33:21 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/3.15-pva2pva-win64s/333/display/redirect>
Changes:
Started by upstream project "3.15-pva2pva-win64" build number 344
originally caused by:
 Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on win64-2 (windows-x64) in workspace <https://jenkins.aps.anl.gov/job/3.15-pva2pva-win64s/ws/>
[3.15-pva2pva-win64] $ cmd /c call C:\Users\jenkins\AppData\Local\Temp\jenkins5423335157299897366.bat
C:\jenkins\win64-2\workspace\3.15-pva2pva-win64>make -j4 -O --no-print-directory EPICS_HOST_ARCH=windows-x64-static
configure/RULES_TOP:2: /configure/RULES_TOP: No such file or directory
make: *** No rule to make target '/configure/RULES_TOP'.  Stop.
C:\jenkins\win64-2\workspace\3.15-pva2pva-win64>exit 2
Build step 'Execute Windows batch command' marked build as failure
Jenkins build is back to normal : 3.15-pva2pva-win64s #334 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: 3.15-pva2pva-win64 #344 APS Jenkins via Core-talk
Next: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : 3.15-pva2pva-win64 #345 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : 3.15-pva2pva-win64s #334 APS Jenkins via Core-talk
ANJ, 06 Dec 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
