2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: OPI updates when enum strings/values change
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, Andrew Johnson <anj at anl.gov>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>, Kevin Peterson <kmpeters at anl.gov>, Matthew Newville <newville at cars.uchicago.edu>
Date: Thu, 4 May 2023 08:37:28 -0700
On 5/4/23 08:30, Michael Davidsaver wrote:
On 5/4/23 08:23, Mark Rivers wrote:
Hi Andrew,
I looked to see how PREC and other fields support DBE_PROPERTY in EPICS base.  I see that the ao, ai, etc. record dbd files put the attribute "prop(YES)" on fields that should generate DBE_PROPERTY callbacks.
I just added prop(YES) to the PREC field in motorRecord.dbd and now when PREC changes Phoebus updates the window to the new precision instantly, without needing to close and re-open the window.  This is great!
A couple of questions:
- If we were to add prop(YES) to fields in the motor record then it would require a minimum of base 3.14.11?
It would actually be >= 3.15.0.2
https://github.com/epics-base/epics-base/commit/3cccdd813458936b536f51589a100cfcfd91f637
My mistake.  This commit adds "prop(YES)" to the base .dbd files.
The C .dbd file parser has always ignored unknown recordtype "items".
(cf. dbRecordtypeFieldItem() ) so I think any 3.14 would ignore "prop(YES)".
RE: OPI updates when enum strings/values change Mark Rivers via Core-talk
Re: OPI updates when enum strings/values change Andrew Johnson via Core-talk
Re: OPI updates when enum strings/values change Michael Davidsaver via Core-talk
Prev: Re: OPI updates when enum strings/values change Michael Davidsaver via Core-talk
Next: RE: OPI updates when enum strings/values change Mark Rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
ANJ, 04 May 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
