2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: OPI updates when enum strings/values change
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>, Andrew Johnson <anj at anl.gov>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>, Kevin Peterson <kmpeters at anl.gov>, Matthew Newville <newville at cars.uchicago.edu>
Date: Thu, 4 May 2023 17:26:47 +0000
Hi Michael,
> The C .dbd file parser has always ignored unknown recordtype "items".
> (cf. dbRecordtypeFieldItem() ) so I think any 3.14 would ignore "prop(YES)".
Thanks, that is excellent, so I don't see any reason not to add those to the motor record.
-----Original Message-----
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Thursday, May 4, 2023 10:37 AM
To: Mark Rivers <rivers at cars.uchicago.edu>; Andrew Johnson <anj at anl.gov>
Cc: core-talk at aps.anl.gov; Kevin Peterson <kmpeters at anl.gov>; Matthew Newville <newville at cars.uchicago.edu>
Subject: Re: OPI updates when enum strings/values change
On 5/4/23 08:30, Michael Davidsaver wrote:
> On 5/4/23 08:23, Mark Rivers wrote:
>> Hi Andrew,
>> I looked to see how PREC and other fields support DBE_PROPERTY in EPICS base.  I see that the ao, ai, etc. record dbd files put the attribute "prop(YES)" on fields that should generate DBE_PROPERTY callbacks.
>> I just added prop(YES) to the PREC field in motorRecord.dbd and now when PREC changes Phoebus updates the window to the new precision instantly, without needing to close and re-open the window.  This is great!
>> A couple of questions:
>> - If we were to add prop(YES) to fields in the motor record then it would require a minimum of base 3.14.11?
> It would actually be >= 3.15.0.2
> https://github.com/epics-base/epics-base/commit/3cccdd813458936b536f51589a100cfcfd91f637
My mistake.  This commit adds "prop(YES)" to the base .dbd files.
OPI updates when enum strings/values change Mark Rivers via Core-talk
Re: OPI updates when enum strings/values change Andrew Johnson via Core-talk
RE: OPI updates when enum strings/values change Mark Rivers via Core-talk
Re: OPI updates when enum strings/values change Michael Davidsaver via Core-talk
Prev: Re: OPI updates when enum strings/values change Michael Davidsaver via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-920 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Build failed: EPICS Base 7 base-7.0-918 AppVeyor via Core-talk
ANJ, 05 May 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
