2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: [Bug 2052814] [NEW] dbLoadRecords with subs=NULL fails to expand macros with defaults
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 09 Feb 2024 15:07:36 -0000
Public bug reported:
A template file that only contains macros with default values can be
loaded with `dbLoadRecords("file.db","")` but not with
`dbLoadRecords("file.db",NULL)`. In particular, in the startup script,
it cannot be loaded with `dbLoadRecords "file.db"` but only with
`dbLoadRecords "file.db",""`. (VxWorks shell as well as iocsh.)
Using such a macro in a record name results in the error message:
ERROR: Bad character '$' in Record/Alias name "$(P=)Name"
Using macros with defaults in fields shows error messages like this:
ERRORName.PREC Has unexpanded macro
Can't set "Name.PREC" to "$(PREC=3)"  : Bad Field value
ERRORERROR failed to load 'file.db'
(Unrelated: Someone please fix the missing blanks after ERROR and the
ERRORERROR.)
The reason is that `dbReadCOM`, the function that does the real work,
only creates a `macHandle` when `substitutions` is not `NULL`. Not
having a `macHandle` prevents any macro substitution from working, even
those which provide a default value.
In the old times, when macros could not have defaults, this was fine,
but not any more. A macro handle should always be created, even if it
stays empty when `substitutions` is `NULL`.
** Affects: epics-base
     Importance: Undecided
         Status: New
** Description changed:
  ERRORERROR.)
- but not any more. A macro handle should always be created, even it it
+ but not any more. A macro handle should always be created, even if it
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/2052814
Title:
Status in EPICS Base:
  New
Bug description:
  ERRORERROR.)
  even those which provide a default value.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/2052814/+subscriptions
[Bug 2052814] Re: dbLoadRecords with subs=NULL fails to expand macros with defaults Andrew Johnson via Core-talk
[Bug 2052814] Re: dbLoadRecords with subs=NULL fails to expand macros with defaults Dirk Zimoch via Core-talk
Prev: Re: pvget -M json is JSON5 Zimoch Dirk via Core-talk
Next: [Bug 2052814] Re: dbLoadRecords with subs=NULL fails to expand macros with defaults Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
ANJ, 19 Feb 2024 · Home · News · About · Talk · Base · Modules · Extensions ·
