2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: [Bug 2052814] Re: dbLoadRecords with subs=NULL fails to expand macros with defaults
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sat, 10 Feb 2024 09:30:42 -0000
Hi Andrew, no problem. Should we then „retire“ Launchpad and fully
switch to GitHub? I find it confusing to have multiple bug trackers for
the same project.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/2052814
Title:
Status in EPICS Base:
  Confirmed
Bug description:
  A template file that only contains macros with default values can be
  loaded with `dbLoadRecords("file.db","")` but not with
  `dbLoadRecords("file.db",NULL)`. In particular, in the startup script,
  it cannot be loaded with `dbLoadRecords "file.db"` but only with
  `dbLoadRecords "file.db",""`. (VxWorks shell as well as iocsh.)
  Using such a macro in a record name results in the error message:
  ERROR: Bad character '$' in Record/Alias name "$(P=)Name"
  Using macros with defaults in fields shows error messages like this:
  ERRORName.PREC Has unexpanded macro
  Can't set "Name.PREC" to "$(PREC=3)"  : Bad Field value
  ERRORERROR failed to load 'file.db'
  (Unrelated: Someone please fix the missing blanks after ERROR and the
  ERRORERROR.)
  The reason is that `dbReadCOM`, the function that does the real work,
  only creates a `macHandle` when `substitutions` is not `NULL`. Not
  having a `macHandle` prevents any macro substitution from working,
  even those which provide a default value.
  In the old times, when macros could not have defaults, this was fine,
  but not any more. A macro handle should always be created, even if it
  stays empty when `substitutions` is `NULL`.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/2052814/+subscriptions
[Bug 2052814] [NEW] dbLoadRecords with subs=NULL fails to expand macros with defaults Dirk Zimoch via Core-talk
Prev: [Bug 2052814] Re: dbLoadRecords with subs=NULL fails to expand macros with defaults Andrew Johnson via Core-talk
Next: Build failed: epics-base base-win32_static_set_thread_names-55 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: [Bug 2052814] Re: dbLoadRecords with subs=NULL fails to expand macros with defaults Dirk Zimoch via Core-talk
ANJ, 19 Feb 2024 · Home · News · About · Talk · Base · Modules · Extensions ·
