2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Re: github ci problem: CAS: forcing disconnect from 127.0.0.1:57020
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: Torsten Bögershausen <tboegi at edom.se>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Wed, 26 Aug 2026 11:25:03 -0700
On 8/26/26 10:25 AM, Torsten Bögershausen wrote:
Thanks for the possible fix.
However:
No good news yet.
I recompiled and quickly run the failed test - It didn't pass
Whatever that means. More digging needed here.
Please update again.  I made a silly mistake, which should now be corrected.
On 2026-08-26 16:08, Ralph Lange wrote:
Oops, sorry. I wasn't aware of last night's changes.
Yes, testing, please!!
~Ralph
On Wed, 26 Aug 2026 at 15:58, Michael Davidsaver <mdavidsaver at gmail.com <mailto:mdavidsaver at gmail.com>> wrote:
    __
    On 8/26/26 6:32 AM, Ralph Lange via Core-talk wrote:
    Feel free to add a comment to #943.
    Temperature increases must be detectable by the frogs.
    Testing would be appreciated.
    https ://github.com/epics-base/epics-base/pull/949 <http://
    github.com/epics-base/epics-base/pull/949>
    On Wed, 26 Aug 2026 at 14:53, Torsten Bögershausen <tboegi at edom.se
    <mailto:tboegi at edom.se>> wrote:
        Thanks for the fast answers.
        After updating EPICS base I can reproduce the problem here.
        It seems to be a caput to a stringout record, which kills the
        business.
        /Torsten
        On 2026-08-26 14:21, Ralph Lange wrote:
        > Might be https://github.com/epics-base/epics-base/issues/943
        <https://urldefense.us/v3/__https://github.com/epics-base/
        epics-base/issues/943__;!!G_uCfscf7eWS!
        fbhB__iF6SebWNlgDxtBowHn7kpX5PFaCpaadsefQivb6hP-
        HkBViEkqdoI6CbPxfEpcCa6FoUBTSougP4T21J-nPQ$> <https://
        > github.com/epics-base/epics-base/issues/943 <https://
        urldefense.us/v3/__http://github.com/epics-base/epics-base/
        HkBViEkqdoI6CbPxfEpcCa6FoUBTSougP4TicZuakw$>>
        > On Wed, 26 Aug 2026 at 14:17, Simon Rose via Core-talk <core-
        > talk at aps.anl.gov <mailto:talk at aps.anl.gov> <mailto:core-
        talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>>> wrote:
        >     Hi Torsten -
        >     Yes, I think I see the same thing. We actually saw it
        last week
        >     during the training at ESS but blamed it on network issues.
        >     This can  be replicated on the 7.0 branch of epics-base
        quite
        >     easily: start an IOC and try (for example) to use caput
        to write to
        >     any record. In the IOC shell I see
        >     CAS: forcing disconnect from 172.18.22.141:59117
        <https://urldefense.us/v3/__http://172.18.22.141:59117__;!!
        G_uCfscf7eWS!fbhB__iF6SebWNlgDxtBowHn7kpX5PFaCpaadsefQivb6hP-
        HkBViEkqdoI6CbPxfEpcCa6FoUBTSougP4Teady_qQ$>
        >     <http://172.18.22.141:59117 <https://urldefense.us/v3/
        __http://172.18.22.141:59117__;!!G_uCfscf7eWS!
        HkBViEkqdoI6CbPxfEpcCa6FoUBTSougP4Teady_qQ$>>
        >     And from the terminal trying to write to the IOC with
        caput I see
        >     $ ./caput record_name 1
        >     Old : record_name                    0
         CA.Client.Exception...............................................
        >          Warning: "Virtual circuit disconnect"
        >          Context: "172.18.22.141:5064 <https://
        urldefense.us/v3/__http://172.18.22.141:5064__;!!G_uCfscf7eWS!
        HkBViEkqdoI6CbPxfEpcCa6FoUBTSougP4RFXw6x9w$>
        <http://172.18.22.141:5064 <https://urldefense.us/v3/
        HkBViEkqdoI6CbPxfEpcCa6FoUBTSougP4RFXw6x9w$>>"
        >          Source File: ../cac.cpp line 1241
        >          Current Time: Wed Aug 26 2026 14:15:06.470965000
        >          Context: "op=0, channel=record_name,
        type=DBR_TIME_DOUBLE,
        >     count=1, ctx="172.18.22.141:5064 <https://urldefense.us/
        HkBViEkqdoI6CbPxfEpcCa6FoUBTSougP4RFXw6x9w$>>""
        >          Source File: ../getCopy.cpp line 91
        >          Current Time: Wed Aug 26 2026 14:15:06.471381000
        >          Warning: "Identical process variable names on
        multiple servers"
        >          Context: "Channel: "record_name", Connecting to:
        > 172.18.22.141:5064 <https://urldefense.us/v3/
        HkBViEkqdoI6CbPxfEpcCa6FoUBTSougP4RFXw6x9w$>>, Ignored:
        > 192.168.205.1:5064 <https://urldefense.us/v3/
        __http://192.168.205.1:5064__;!!G_uCfscf7eWS!
        HkBViEkqdoI6CbPxfEpcCa6FoUBTSougP4R8uNNpZQ$>
        <http://192.168.205.1:5064 <https://urldefense.us/v3/
        HkBViEkqdoI6CbPxfEpcCa6FoUBTSougP4R8uNNpZQ$>>"
        >          Source File: ../cac.cpp line 1324
        >          Current Time: Wed Aug 26 2026 14:15:06.475347000
        >     Read operation timed out: PV data was not read.
        >     New : record_name
        >     Something is wrong here...
        >     Cheers,
        >     Simon
        >     *From: *Core-talk <core-talk-bounces at aps.anl.gov
        <mailto:core-talk-bounces at aps.anl.gov> <mailto:core-talk-
        <mailto:core-talk->
        > bounces at aps.anl.gov <mailto:bounces at aps.anl.gov>>> on behalf
        of Torsten Bögershausen via Core-
        >     talk <core-talk at aps.anl.gov <mailto:core-
        talk at aps.anl.gov> <mailto:core-talk at aps.anl.gov <mailto:core-
        >     *Date: *Wednesday, 26 August 2026 at 13:59
        >     *To: *core-talk at aps.anl.gov <mailto:core-
        talk at aps.anl.gov>> <core-
        >     *Subject: *github ci problem: CAS: forcing disconnect from
        > 127.0.0.1:57020 <https://urldefense.us/v3/
        __http://127.0.0.1:57020__;!!G_uCfscf7eWS!
        HkBViEkqdoI6CbPxfEpcCa6FoUBTSougP4SdmPgehw$>
        <http://127.0.0.1:57020 <https://urldefense.us/v3/
        HkBViEkqdoI6CbPxfEpcCa6FoUBTSougP4SdmPgehw$>>
        >     Hej EPICS-experts,
        >     since some time (July 10 2026 or 2026-07-10) we have a
        failure
        >     on one of our github runners.
        >     If someone wants to look, here is a good run:
        >     <https://urldefense.us/v3/__https://github.com/
        <https://urldefense.us/v3/__https://github.com/>
        >     EuropeanSpallationSource/m-epics-ethercatmc/actions/
        >     runs/29092838578__;!!G_uCfscf7eWS!
         Zp_A98G8tvAmH3xmEtRxKFl_0Ydm7Wz0MSRmQ1ZrULhuV4JUEssosb0rF6Cv3MthfRkOlH0LmK79aHPdMb8$ <https://urldefense.us/v3/__https://github.com/EuropeanSpallationSource/m-epics-ethercatmc/actions/runs/29092838578__;!!G_uCfscf7eWS!Zp_A98G8tvAmH3xmEtRxKFl_0Ydm7Wz0MSRmQ1ZrULhuV4JUEssosb0rF6Cv3MthfRkOlH0LmK79aHPdMb8$ <https://urldefense.us/v3/__https://github.com/EuropeanSpallationSource/m-epics-ethercatmc/actions/runs/29092838578__;!!G_uCfscf7eWS!Zp_A98G8tvAmH3xmEtRxKFl_0Ydm7Wz0MSRmQ1ZrULhuV4JUEssosb0rF6Cv3MthfRkOlH0LmK79aHPdMb8$>> >
        >     One of the failing runs is here:
        >     runs/32959143825/job/98147389788__;!!G_uCfscf7eWS!
         Zp_A98G8tvAmH3xmEtRxKFl_0Ydm7Wz0MSRmQ1ZrULhuV4JUEssosb0rF6Cv3MthfRkOlH0LmK79fn7GMoM$ <https://urldefense.us/v3/__https://github.com/EuropeanSpallationSource/m-epics-ethercatmc/actions/runs/32959143825/job/98147389788__;!!G_uCfscf7eWS!Zp_A98G8tvAmH3xmEtRxKFl_0Ydm7Wz0MSRmQ1ZrULhuV4JUEssosb0rF6Cv3MthfRkOlH0LmK79fn7GMoM$ <https://urldefense.us/v3/__https://github.com/EuropeanSpallationSource/m-epics-ethercatmc/actions/runs/32959143825/job/98147389788__;!!G_uCfscf7eWS!Zp_A98G8tvAmH3xmEtRxKFl_0Ydm7Wz0MSRmQ1ZrULhuV4JUEssosb0rF6Cv3MthfRkOlH0LmK79fn7GMoM$>> >
        >     Of course the tests run fine here on a local machine
        >     (with probably sighly different versions)
        >     So digging into the log file shows one problem:
        >     Wed Aug 26 11:21:03 UTC 2026
        >     + ./runTests.sh ca://IOC:m1 100_Record-HOMF.py
        >     CAS: forcing disconnect from 127.0.0.1:48202 <https://
        urldefense.us/v3/__http://127.0.0.1:48202__;!!G_uCfscf7eWS!
        HkBViEkqdoI6CbPxfEpcCa6FoUBTSougP4SHrkr2ag$>
        <http://127.0.0.1:48202 <https://urldefense.us/v3/
        HkBViEkqdoI6CbPxfEpcCa6FoUBTSougP4SHrkr2ag$>>
        >     #... and later, PYT stands for the output of pytest:
        >     PYT:2026-08-26 11:21:04 AxisCom get ca://IOC:m1.VAL
        ret=100.11
        >     PYT:2026-08-26 11:21:04 AxisCom get ca://IOC:m1.DMOV
        >     PYT:cannot connect to IOC:m1.DMOV
        >     PYT:2026-08-26 11:21:09 AxisCom get ca://IOC:m1.DMOV
        ret=None
        >     Before I try to set up a system with the hopefully exact
        versions as
        >     on github:
        >     Does a bell ring for anybody here ?
        >     The commits in EPICS base show that some additional
        checks had been
        >     introduced when processing channel access messages in rsrv
        >     However, we are using pyepics inside the test cases,
        which uses
        >     the libca from base, so things should work.
        >     (And yes, Timo, we are using mostly pvacess for 99% of
        the tests)
        >     Any ideas are welcome
        >     Best Regards
        >     /Torsten
    ____
Re: github ci problem: CAS: forcing disconnect from 127.0.0.1:57020 Torsten Bögershausen via Core-talk
Re: github ci problem: CAS: forcing disconnect from 127.0.0.1:57020 Simon Rose via Core-talk
Re: github ci problem: CAS: forcing disconnect from 127.0.0.1:57020 Ralph Lange via Core-talk
Re: github ci problem: CAS: forcing disconnect from 127.0.0.1:57020 Michael Davidsaver via Core-talk
Prev: Re: github ci problem: CAS: forcing disconnect from 127.0.0.1:57020 Torsten Bögershausen via Core-talk
Next: Re: github ci problem: CAS: forcing disconnect from 127.0.0.1:57020 Torsten Bögershausen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
ANJ, 26 Aug 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
