<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: sysBusTas problem
Date: Sun, 24 Apr 94 16:58:48 PDT
 I am debugging an application which has two VME crates
 connected by a Bit3 413-1 bus coupler.   This coupler
 allows processors in each VME crate to transparently access
 memory which is in the other crate, and also has 2MB of
 on-board memory which can be accessed by either crate.
 We use EPICS 3.11.1 and vxWorks 5.1, the processors are Motorola
 MVME166s and MVME167s.
 I am using sysBusTas() to test semaphores in each memory
 which are used to prevent access conflicts across the Bit3
 coupler.  This is necessary because the Bit3 is essentially
 a half-duplex device.
 The problem is that, occasionally, one of the tasks will get a
 bus error accessing the memory on the Bit3 coupler, and at the
 same time, another task will hang in  _vxTas, trying
 to access the semaphore in the other VME crate.  _vxTas
 is the kernel routine called by sysBusTas.  The Bit3
 documentation states that RMW instructions between the
 two VME busses are supported.
 If anyone else has experienced test-and-set problems,
 with Motorola cpus or problems with the Bit3 bus coupler,
 I would appreciate your suggestions.
 Bob Belshe
 Gammasphere Data Acquisition
Prev: Re: hkv2fs and 68060 boards winans
Next: Re: Tracewell crates mcgehee
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: applications that use channel access Jeff Hill
