<1994>  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <1994>  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Fast data logging
Date: Mon, 1 Aug 1994 11:28:11 -0700
Dear all,
I am looking at archiving data from hardware systems at fast rates: 200Hz
or so. The following are some thoughts I've had about it and I wonder if
anyone else is also dealing with this issue.
I don't I would want to drive the logging at 200Hz via normal record processing.
What I had in mind was to have the record associated with the data create a
standalone VxWorks task at init_record() which would be responsible for
the communication with the device in question (PMAC?) at the 200Hz rate and store
it in an internal circular buffer.
>From the EPICS record processing point of view the record could be queried at
a slow rate via the normal EPICS scan task mechanism and the resulting array
sent out to AR via channel access.
Pergrine
_______________________________________________________________________________
Peregrine M. McGehee			Controls Group
Gemini 8-Meter Telescopes Project	PO Box 26732, Tucson, AZ 85726-2632
E-mail:	[email protected]		Phone: (602) 321-3423
Prev: Re: record processing overhead Paul Banta
Next: Re: Fast data logging watson
Index: <1994>  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
